RV.Net Open Roads Forum: General RVing Issues: Dewinterizing Surprise
 > Dewinterizing Surprise
Exocet
Central NY, USA
Posted: 05/10/08 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
I finally got around to dewinterizing the TT today. I was going to flush out the hot water heater and when I removed the drain plug, out came 1-2 gal of water. Apparently, it's been there all winter. I drain the water heater after every trip, so I'm a bit puzzled, but I apparently missed something somewhere last fall. I filled up the water heater and fired it up and fortunately no leaks. The only other problems found were a dead clearance light and the switch to the power tongue jack didn't want to work. I got those problems fixed in short order. Now all the TT needs is a top to bottom cleaning, and we'll be all set to go.
2008 Nissan Titan SE, Crew Cab, 4x4
Long Bed, Big Tow
2006 Rockwood 2501
Equal-i-zer
Tekonsha Prodigy
mockturtle
Northwest
Posted: 05/10/08 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
Someone must have turned on a hot water tap before the bypass was applied.
2000 Aerolite 19RB TT
1996 Chevrolet Blazer 6 cyl. 4WD
This car used to be our toad, now is our TV!
2oldman
WA
Posted: 05/10/08 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
You got lucky.. you didn't leave it full.
rick_niagara
Niagara Falls, Ontario, Canada
Posted: 05/10/08 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
We always leave the drain plug out during the winter.
2008 Fleetwood Prowler 235RLS
2005 Dodge Ram 2500 4x2 5.9L Diesel 3.73Limited slip 6speed manual
Pullin' 5ers since 1988....Have a nice day
skipnchar
Topeka Kansas USA
Posted: 05/10/08 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
I've seen folks who leave drain plugs out and then find critters nesting in the water tank next spring. I suspect you either didn't get it bypassed before someone turned on the pump or water or else you have a leaky or not completely closed by-pass valve or check valve allowing some back fill. Nothing too serious though since it wasn't full enough to cause a problem. I would also suggest that your water tank will probably last longer if you stop leaving it empty between uses. It's NEVER going to be completely dry and with a damp area like that it promotes oxidation. It would be better off left full during the summer months. Just my opinion / Skip
KC8WX
OH IO
Posted: 05/10/08 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe missed the Low Point Drains? I leave the Anode a little loose so it will leak off if anything in there, yet no critters getting in.
2006 Durango SLT 4.7L, 545RFE, 4.10 Motive Gears with TracLoc 2WD AIRAID Cold Air Intake, PML Deep Tranny Pan, KYB Shocks
2007 Wildwood LE 27RB
Equalizer Hitch
Prodigy Brake Controller
