I am considering a Super C to replace 5th wheel toy hualer. Would like to use 1/2 ton pickup as a two vehicle to accommodate motorcycle. Any suggestions which 1/ ton can be used with 4 wheels down.
pnordan wrote: I am considering a Super C to replace 5th wheel toy hualer. Would like to use 1/2 ton pickup as a two vehicle to accommodate motorcycle. Any suggestions which 1/ ton can be used with 4 wheels down.
Just about any 4WD (not AWD) vehicle can be towed. You will need to check owners manual to see which models can be towed. I know one person that is towing a Tahoe with his Super C. That comparison should get you into just about any 1/2 ton GM truck.
I tow a 2006 Tahoe with my 2007 Four Winds Super C (model 33K), but the wheelbase is too short (213.5 inches). I suggest you find an RV with as long a wheelbase as possible which can also give you a shorter rear overhang. This will keep your coach from side slipping (tail wagging the dog) when going down the highway. Keep in mind the tow bar weight (mine is about 80 lbs. should be included in the overall CCC in the coach.
