RV.Net Open Roads Forum: Travel Trailers: 1200 Watt generator ? Big enough ?
 > 1200 Watt generator ? Big enough ?
ajmorro67
Arizona
Posted: 05/10/08 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
Correction, AC in my trailer draws 15amps. 15a x 120V = 1800W. Not 18 x 120.
smkettner
Posted: 05/10/08 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
1800 is running watts. Start up watts is what is generally the problem.
A 2000 Honda should run most 15k air conditioners but may not get them started.
Pete D
Washington
Posted: 05/10/08 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
Some of the generator sites have a handy checklist of items that you can add up to get the needed size.
What I don't think I saw mentioned above is the each a/c model has different specs, so YOUR a/c may or may not run on a small generator. Also, even more important than what it takes to run it is what it takes to START it; starting current will be momentarily very high. That info can only come from measurements by a technician or from the manufacturer. Be sure to enquire as to a "hard-start" kit to make starting easier.
Some people in small trailers run 5KBTU a/c from BigBoxStores rather than larger bulgemobile a/c's, so the answers may be different.
You will find that if you can keep the generator size down to the inverter-based models that run on eco-mode, they will be significantly quieter than the larger ones that have to maintain RPM to maintain 60Hz.
1998 Ranger 4.0 4x4
1991 Scamp 13'
Dixonmatco
Santa Rosa, California
Posted: 05/10/08 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
One of the commom setups to do what you are looking for is a pair of Honda EU2000I. They can be connected together to provide 4000 watts. If not using the Air Conditioner, you only need to run one. Even as a pair, the Eco mode lets them idle down if the load is small. They are lightweight enough to lift and move easily at less than 50 lbs with a tank of fuel each. Price at $860 each from Wise makes them even a bit less than a 3000w.
Now the best parallel kit for them is $255 but if you do a search, there are many here that have made their own for much less $$.
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
crickeydog
Marietta, Ga.
Posted: 05/11/08 06:12am Link  |  Quote  |  Print  |  Notify Moderator
RazBarlow wrote:
just wondering if a 1200 watt generator would be large enough to run my travel trailer ?
Nope!!! Not even close.
Happy camping!!! See ya'll down the road!!!
AIR FORCE RETIRED "EITHER LEAD,FOLLLOW,OR GET OUT OF MY WAY"!
2006 GMC 3500 SLT CC DRW 4X4 D/A LBZ,PREDATOR & FS2500 OIL FILTER
2004 HR PRESIDENTIAL 30 SCD 5'ER.
CHEROKEE & CHEYENNE, MINI DOXIE'S
LOADED LIKE A FREIGHT TRAIN, FLYIN LIKE A JET PLANE!!
retired1
arizona
Posted: 05/11/08 06:59am Link  |  Quote  |  Print  |  Notify Moderator
We have a 1200 watt Champion and it will run the lights and charge the battery. Thats about it.
Retired1
