sandiegotravelers
San Diego, CA
Has this ever happened to you?
Hooked up to sewer at recent trip to RV park. Checked water levels and gray was full. Went outside and pulled gray water lever to empty. Later that day the shower started to back up. Level indicator was showing full still. Went outside and pulled lever for gray and nothing was coming out. After using a plunger for 30mins and not getting anywhere, father-in-law pulled the "black" water lever and.....SWOOSH!! Water started to subside in the shower.
Answer: Make sure the factory has labeled your drain valves properly.
Thanks to Fleetwood (or whoever placed the labels on) I have been emptying gray first and black second.
Luckily I have a label maker.
2007 Fleetwood Wilderness Scout 27' TT
2005 Ford Expedition Eddie Bauer 5.4L V8 FI SOHC
EAZ-LIFT Weight Distribution Bars
NHguy
NH
OOOH, I hope you don't need to do a black tank solids break up.
At least it was a mis label instead of shower connected to black, now that would be gross.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, XM Cradle, Battery Disconnect
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
DocP
Brunswick Hills, Ohio
My last 2 new TT's were mislabeled as well. Since I use the Flush King (which is clear) it was easy to spot (and change the labels).
2008 Keystone Freedom Lite 281RL
2004 Chevy Avalanche, 5.3L, 3.73:1, 4X4,
Auxiliary transmission oil cooler,
Z71 off-road towing package
Reese Trunnion WD, Dual Cam, Prodigy
Yamaha EF2400IS generator
Capn Courage
Ontario
Was it just the labels that were wrong or were the valves wrong too, the black tank valve is always larger than the grey tank valve.
Norm
Capn & Mrs. C
2004 Rockwood RLT23FB
2002 GMC Safari
Eaz-Lift W/D hitch
Reese Anti Sway
Hoseman
Westfield
As a rule of thumb I always emty both tanks when I dump then I know that both are empty. Its a stinky mess and I think several of us have had this happen I did to good luck I hope it wasnt to much of a disaster.
Chuck&Gail
In the Colorado Mountains
Mines like Norm says, gray pipe and valve MUCH smaller than black tank pipe and valve.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 4 Canada Provinces, & 2 Territories.
92DakotaHD
Indiana
Yeah, Grey is usually 1.5-2" and the Black is usually 3" or bigger.
1992 Dakota 2WD 5.9L V8 (NOT Stock)
Headers, FMS Injectors, Ported TB, MP PCM (not good for towing),
2005 Chevy Tahoe Z71- Bermuda Blue, A/T Revo 265/70 "E"
Prodigy Controller
Pioneer 17T4 Just PERFECT for Two!
Gone Racing!
A newbie, any tips please share!
Hornet28BHDS
Parker, PA
Well, now you know!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
Luvpitts
Conyers, GA
Our gray tank fills up fast. Even when the fill indicator said 1/2 full we had water backing up into the shower.
I don't understand that one... Any ideas??
Claudia (the computer geek) & Wayne
Semper Fi!
2007 Ameri-Camp T306LE
2006 Ford Excursion
*I'd include pics, but can't figure out what I'm doing wrong with the size of them!!
WHY didn't Noah SWAT those two mosquitoes???
Dixonmatco
Santa Rosa, California
Luvpitts wrote: Our gray tank fills up fast. Even when the fill indicator said 1/2 full we had water backing up into the shower.
According to the specs for your trailer, you have a single 38 gal grey tank. For any more than two people that will fill up in about 2 days. One way to conserve is to dump the dishwater down the toilet, into the black tank, as that usually takes longer to fill up. The fact that the guage is inaccurate is pretty normal.. When it backs up into the shower, it is full.
If you have kids, you need to teach them to not just let the water run like they do at home.
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
