RV.Net Open Roads Forum: Travel Trailers: Wheres fresh water drain cock?
 > Wheres fresh water drain cock?
Hornet28BHDS
Parker, PA
Posted: 05/11/08 11:55am Link  |  Quote  |  Print  |  Notify Moderator
It should be right near the drain line.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
scottcougar
Saskatchewan
Posted: 05/11/08 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
no. its not. i have some fitting on there thats it? would the drain petcock be inside the belly? i doubt it? maybe ill just cap it off somehow?
gijoday
Unicoi, Tennessee
Posted: 05/11/08 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
On my xlite 26fb, drain petcock is about 6" ahead of front axle in the center of trailer.
scottcougar
Saskatchewan
Posted: 05/11/08 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
ok thanks. i found my low point drains. theres 2 of them on the passenger side behind last axle towards back of trailer. All i did was plug or block off that line and all is good now. wish there was a petcock. i could put a ball valve in to.
SuperDutyMan
Western PA.
Posted: 05/11/08 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
Mine has no valves and Polar Package,3 caps just screw on ,your FW cap probably got lost and fell off.
2008 Keystone Cougar XLite 29RLS
2006 Super Duty V10 6 Speed 4.10S Tow Command Tow Pkg. 4X4
scottcougar
Saskatchewan
Posted: 05/11/08 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
thanks. i spent 6 hours looking for drain valve. i opened every panel and hidden panel that could come off. I was about to pry the rug up.
mehwwh
Posted: 05/11/08 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
Wouldn't a call to you rv dealer have helped?
'03 Silverado 1500, Ext.Cab, Z71 Off Road, 4X4, 5.3L, 3.73 rear, AutoMeter Trans Temp Gauge, Putnam Class IV
'08 Jayco JayFlight G2 23FB, Reese WD Hitch, HP Dual Cam Sway, 800# Trunnion Bars, Barker 3000# Power Tongue Jack
Orion
Pacific South West
Posted: 05/11/08 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
I do not have little taps on mine, just inside threads. BTW I keep my caps in the water heater during the winter so I don't lose them.
Never miss an opportunity to walk on the grass.
PAWA
Washington
Posted: 05/11/08 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe. Last fall, when preparing to winterize my TT for the first time, I couldn't find the low-point drain. In desperation, I finally called the dealer's service center. Eventually I spoke to the lead service supervisor, who told me that the location varied from unit to unit, completely at the whim of the installer at the factory. He gave me a list of the "usual" places they find them, and I found mine behind the rear bumper, below my galley sink. I guess they helped, because I learned there was no standard drain placement according to unit model.
scottcougar
Saskatchewan
Posted: 05/12/08 06:01am Link  |  Quote  |  Print  |  Notify Moderator
now that i think of it there was a cap in the water heater compartment on the outside of the trailer.lol my bad.
