rshamner
Alabama
Quick question to anyone who has experience with this.
We just got our fifth wheel and are packing it out in the driveway. We have our power adapted down to a 120 connection. Is it OK to run the AC off this connection? Getting hot here....
Thanks
Scott
edited 05/11/08 09:15am by rshamner *
Rolling With the Tide
2008 KZ Durango LX 3354PX3
2008 Dodge Ram 3500
crickeydog
Marietta, Ga.
Probably but that's all you can run and use as short of a cord as possible. You're still powering the converter. Make sure your refrigerator and water heater are either off or on propane and to make the a/c startup power surge easier on the compressor, set the a/c fan blower to run on low constantly.
Happy camping!!! See ya'll down the road!!!
AIR FORCE RETIRED "EITHER LEAD,FOLLLOW,OR GET OUT OF MY WAY"!
2006 GMC 3500 SLT CC DRW 4X4 D/A LBZ,PREDATOR & FS2500 OIL FILTER
2004 HR PRESIDENTIAL 30 SCD 5'ER.
CHEROKEE & CHEYENNE, MINI DOXIE'S
LOADED LIKE A FREIGHT TRAIN, FLYIN LIKE A JET PLANE!!
Scarface56
Appleton, Wisconsin
It all depends on what the amperage is for the circuit you are plugged into. It should be at least a 20amp breaker to run the air. You didn't state whether you have a 30amp or 50amp service in your RV??
Just Me & DW
2008 GMC 3500 SLT DRW Diesel
Pioneer AVIC D3 GPS Nav/Stereo/backup camera
2007 276RLS Cougar 5th wheel by Keystone
Scooter Buddy 125
17.5 Crestliner Boat
For those of us who fought for it, freedom has a flavor the protected will never know.
rshamner
Alabama
I have 50 amp service
Fishinghat
Western Washington, USA
If you have 50 amp service to your coach, you can run anything and everything anytime. But, if you are plugged into a 15 or 20 amp outlet, then you'll have to limit the current draw as crickeydog suggested. JMHO
Holiday Rambler Navigator DP, Mustang Convertible, and Honda VT1100C Shadow.
fla-gypsy
North Florida
I am able to run mine on a dedicated 20 amp circuit as long as nothing else is on. My problem is it takes a 100' cord and I get significant voltage drop even using a 10 gauge extension cord.
05 Super Duty XLT CC 5.4/3.73 5 sp auto Torqshift
06 Keystone Hornet 29 RLS/(The"Cracker Cabana")
Reese HP Dual Cam
Camping Photos
Northeast Florida Camping Club
St Andrews SP cult member
kaydeejay
SE Michigan, USA
Hopefully the ONLY connection you plug into is 120V!!!
The only question is the current rating.
A standard home outlet is 15amps, not quite enough for your air conditioner.
20 amps is a minimum.
If this is something you are going to want to do on a regular basis I recommend you install (or get an electrician to install) a 30amp RV outlet.
Even though your rig is a 50A service, you will be able to run one A/C on 30A.
Installing 50A at home will get quite a bit more expensive and, IMHO is not really necessary.
Keith J, Retired from GM Engineering
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA.
1999 Sunnybrook 27RKFS Fiver
Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors.
PapPappy
Wilmington, NC
I concur with Keith and the others. You will want at minimum 20A service for that adapter plug you have, but would be much better served with the 30 outlet that you can connect to as needed. I've run a 20A outlet, but plan to upgrade in the near future. I can run the A/C, but don't leave it on very long. But do leave the Refrigerator on all the time. I've got the voltage meter plugged in in the galley, so I can monitor if there is too much load loss. 30 Amp service will be put in when I get my Tax refund....
Bill, Claudia, and the Paps
DH Bill / DW Claudia / DD Jenn / DS Chris
The Paps! Sophie, Abby, Brandy, Kahlie and Annie
Purchased April Fools Day, 2008
The Pets
Big Katuna
Deland, FL
Most modern homes have at least one 20A recep in the garage somewhere. Mine has one on each wall. The others are 15A. If you have room, as someone else said, add a 30 to your panel. You can have the recep next to your breaker panel and buy a 30A ext cord if you need it. One day camping you will need it anyway.
My Kharma ran over my Dogma.
smkettner
Watch your voltage stays 108 or above inside the RV once the air is running.
