Espee
Valencia, Ca
I have a 2 year old Cougar and have tried to keep up on the wax and regular wash of the rig... maybe I should have waxed it every month. The fiberglass front of the 5er gets direct sunlight, and the edges of the decals / stickers are starting to lift up (only here so far). Anyone find a way to stop or reatatch them before it gets worse? I was thinking maybe there is some 3M product that could be painted behind and then lay the edges that are lifting back down? Any other ideas? Kinda' a bummer. I thought maybe I would get at least 5 years or more with the wax and ProtectAll inbetween...
Patriot 2007.5 Dodge 2500, QC, SLT, BH, 4X4, SB, 6.7 CTD w/EB, 68RFE, 3.73's, posi
06' Cougar 285EFS, custom hldg tnks
Honda EU2000i, Trojan T105's, Portawatz 1750, DISH.... all just for roughin' it!
rob85546
Hot arizona
Heck I bought a 2002 keystone in 2003 NEW leftover and the stickers were peeling..but I see that in all brands..
maybe take them off before it really is noticeable when they finally have to come off....
Espee wrote: I have a 2 year old Cougar and have tried to keep up on the wax and regular wash of the rig... maybe I should have waxed it every month. The fiberglass front of the 5er gets direct sunlight, and the edges of the decals / stickers are starting to lift up (only here so far). Anyone find a way to stop or reatatch them before it gets worse? I was thinking maybe there is some 3M product that could be painted behind and then lay the edges that are lifting back down? Any other ideas? Kinda' a bummer. I thought maybe I would get at least 5 years or more with the wax and ProtectAll inbetween...
2007 GMC DURAMAX,LBZ,4 by Crew, Allison
Magnaflow Turbo Back Exhaust
Predator Tuner
18by9 Helo's on BFG's
5year old boy
3 year old baby girl
Sea ray boat
Wilderness 5th wheel
SandRail
HD WideGlide
FORD Expediton
honda Eu3000
agesilaus
North Florida
Maybe you might think about buying a cover
BK
04 Trail Manor 2619
08 Ford F150 5.4L TV
USAFBILL
Alabama
I think some Wax has a bad effect on the decals....I just took mine off except for the lower stripe. Looks a lot better IMO.
2003 Cougar 285EFS
2000 Chev 2500 Ex Cab
Sargehut234
Cajun Country
We have a Montana and the "owners manuel" does not recommend waxing decals as
the wax will oxidize and cause the decals to fade and crack. I use a vinal
protectant on the decals and never wax them. Hope this helps in the future.
SARGE
crbatten
Camas, Wa. 98607
I use Aerospace 303 on my fiberglass siding as well as the striping on the 5er as well as the front cap, they are holding up good. crb
2004 Silverado 4X4 2500-HD, Duramax/Allison
2004 Keystone Challenger-29RKP
crb/gab/retired/0505
Bigdog
silverdale wa.
I have only waxed the whole rig once but do the front about every 4 months and have noticed that some of the graphics there are starting to show signs of cracking,etc.. I usually wash the rig with either Turtle wash and wax or the gold stuff that I can get at Costco sometimes and am having no problems with the rest of the graphics..I was using a real expensive Carnuba wax that I bought for my old BLACK Suburban as it seemed to be the only stuff that didn't melt off of it in the summer..Now I'm only using dish soap on the whole rig and it really does a good job..I have also found that all the stuff you use for black streaks tend to remove the wax also..I'm gonna try the Lava soap in a sock that was suggested in Trailer Life last month..
GO COUGARS
2001 Ford 7.3L PSD Excursion
Ride Rite air bags
AFE Stage1 air-inlet
4"MBRP exhaust
Hellwig rear sway bar
2005 Keystone COUGAR 304BHS
Tekonsha Prodigy
1200 Equalizer hitch
2008 Thomas w/Mercedes-Benz 78 pass. school bus
tatest
Oklahoma
Waxing might be the problem. An automotive wax with distillate solvents will dissolve the glue under the vinyl, from the edges in.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
countryrose
Redding, Ca
Had the same problem on our 2004 Keystone.
Hornet28BHDS
Parker, PA
Sargehut234 wrote: We have a Montana and the "owners manuel" does not recommend waxing decals as
SARGE
Sounds like your problem!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
