RV.Net Open Roads Forum: Travel Trailers: what TV is oulling your 27BH
 > what TV is oulling your 27BH
StillOnThePot
California
Posted: 05/11/08 10:58am Link  |  Quote  |  Print  |  Notify Moderator
My TV (04 Ford F250 6.0 PS)got stolen and still not found. we have a Jayco 27BH G2 with a dry weight of 5k pounds. so , what are u using to pull yours? i am now in the market and i am debating on what to replace my TV with. Gasser vs Diesel, Old vs New, etc..
So some Questions:
1: what is tow vehicle
2: What is mileage empty and towing
3: how is maitenence on vehicle
4: Are you happy with rig
5: if u can switch TV, would you?
6: do you tow with full tank of water?
7: how does rig handle in mountains?
thanks in advance
TXiceman
(Near) Houston,TX
Posted: 05/11/08 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
First off...forget you ever heard of dry weight or unloaded vehicle weight, unlss you never plan to put any supplies in the trailer.
While you may never load the trailer to GVWR (gross vehicle weight rating) use this number for finding a tow vehicle.
Most trailers when loaded will weight a fair amount over the UVW.
I can tell ou for a fact that once you have pulled with a diesel, you will notbe happy going back to a gasser. I tried and I decided to keep my diesel.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
mxaaron
Seattle
Posted: 05/11/08 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
My Komfort Bunkhouse is about 8000-8750 lbs loaded for Kamping (You don't Camp in a Komfort, you KAMP!!!)
1. I haul it with a Dodge Ram Cummins 3/4 ton 4X4 with a Manual trans. It does great.
2. I get about 13.5 towing my Komfort, and around 20 on the highway empty.
3. I do all the maint, from oil, filter, fuel filters, air filters, and my buddy is a tranny tech, and he services all of my powertrain needs.
4. Love it.
5. Yeah, to a newer six speed cummins.
6. Tow with or without water, and the configuration of our Komfort makes a better tow with more water. It has a light tongue weight, which is helped by towing with the front water tank heavy.
7. Haven't seen a pass I couldn't climb! Really though, it does great. All of the diesels do. But if you ask me, the defining factor with the diesels is that the manuals just pull better. Sucks in rush hour, but once you hook them to the trailers, they are in their element.
Good luck choosing.
Aaron.
Aaron.
* This post was edited 05/11/08 01:50pm by mxaaron *
StillOnThePot
California
Posted: 05/11/08 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
anymore 27BH owners out there?
Hgarnerno1
Tyler, Texas USA
Posted: 05/11/08 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Terry 27H which is probably the same TT weight wise and size wise. I pull it with a 2000 Excursion with the V-10. I get around 7-10 towing and around 15-16 solo. It is the best tow vehicle I have every had. I did have a Suburban and it does not compare to the Ex. I know they do not make them any more, but if you could find a good 2004 or earlier I do not think you would be disappointed. You can find them gas or diesel, but with the price of diesel fuel now days you would probably be better off with the gas model. I have had it in the mountains and it does a supurb job. Good Luck in your search.
Howard, USN Ret
2000 Ford Excursion,V10, Limited
2003 Terry 27H. Super Slide
AJS211
new york
Posted: 05/11/08 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
We have a sunset creek 27 ft BH and we pull it with a 05 F350 PSD. We used to have a F150-no comparison!!!!
Anthony, Janice, Little Anthony & Butch the Dog
05 Ford F350 Lariat Supercrew PSD
08 Sunnybrook Sunset Creek 269BH
swebber
Brunswick , MD
Posted: 05/11/08 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
We had an '05 Jayflight 27BH...loved it until DW found current TT last year.
We pulled it with '05 F150, 4.6L v-8, Auto trans, 3.73 rear with factory tow package..was very anemic but never gave up. The 5.4 V8 and 3.73 in the F150 would be minimum for your TT.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
Hemisport
Prince George BC
Posted: 05/11/08 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
I have the 27BH G2 I tow with a 08 ram with the Hemi. Pulls the trailer fine I get about 11 MPG towing and about 116 on the Hwy. I only have 6000 kms on my truck so it will get better aftwer it breaks in a bit.
silvercrew
Brooks Alberta
Posted: 05/11/08 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
We tow our trailer most of the time with our expedition as seen below. I also have towed my trailer with a 05 ford f250 6.0l psd and right now I am using a 07 dodge 2500 cumins. I can't wait to get my trailer behind a new ford f350 6.4l psd. In my opinion the ford did a way better job of towing than the dodge but both do beat the expedition for towing hands down. DIESEL all the way.
2004 Expedition EB 5.4l hd tow pack
2005 Triple E Topaz LE T274XL
Prodigy brake control
Equal-i-zer hitch
Cipa mirror extensions
Proforce gen set
Colman LXE grill
RedRaider44
Posted: 05/11/08 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
I pull my 27BH with the truck in my sig, a 2002 F250 CC 5.4l gasser.
Adequate on the flats, struggles in the hills.
We went to Colorado last summer and I spent way too much time in second gear for my comfort level. Good stable platform, but underpowered in the hills.
Steven
2004 Jayco 27BH
2002 F250-CC
