RV.Net Open Roads Forum: Tow Vehicles: Cummins issue, rattling/pinging only @ certain rpms?
Search only in Tow Vehicles
 > Cummins issue, rattling/pinging only @ certain rpms?
rjsurfer
North Carolina
Posted: 05/11/08 11:45am Link  |  Quote  |  Print  |  Notify Moderator
On my last trip out pulling our 5th wheel I noticed what sounds like pinging, marbles or rattling sound only at certain rpm's??
At first I thought it might be a lift pump issue (60,000 miles), but I did a search on that and found that there is never any noise associated with a lift pump, only a lose of power and eventual distruction of the injection pump.
The problem rpm's are 1700 & 2100, the more throttle I give at those rpm's the louder the noise. Now if I stop for gas or let it idle for awhile the sound goes away until 10 minutes into getting back on the road towing.
I have been through 4 tanks of diesel since this started with no change in symptoms and there is NO loss of power, at least so far.
Any ideas? Before you say take it to dealer, I'd rather fix it myself.
Ron W.
03 Dodge 2500 SRW,SB,EC
2008 Keystone Cougar 245RKS 5th Wheel
DRZ-400SM
DL-650
ffemt1271
Louisiana
Posted: 05/11/08 11:59am Link  |  Quote  |  Print  |  Notify Moderator
you stopped for GAS.. theres your problem, just kidding. when i start off from a dead stop and get into it and it levels out after going thru the gears it makes a rattling noise for about 3 seconds and then stops. mine has done that since new but only when pulling my 5er or tractor i've got 98K on mine
Professional Firefighter/EMT
2003 DODGE 2500Hd/ cummins
2001 dutchman 27rk 5er
Prodigy Controller
ck1
Murrieta Ca.
Posted: 05/11/08 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
run a can of Seafoam or power service in your tank first. my does it also when I get some garbage fuel...I change the filter every 10k and put a can in the fuel filter canister and another can in the tank...smooths it out real fast...seafoam is good stuff...try that before wasting your time at the dealer....my two cents
cameron
2003 3500 Heavy Duty quad Cab 2wd SLT CTD DRW Auto 4.10
2008 Lance 1055
98 VW Jetta TDI...
47 Ford Super Deluxe Coupe
95 Jeep wrangler
67 ford Falcon
photos: http://community.webshots.com/user/ck1105
Kenneth
Washington, the state
Posted: 05/11/08 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
Seafoam...put a can in the fuel filter canister....
NO! Seafoam has no lubricity. It must never be in the fuel system by itself. I'm not sure it does any good in a diesel, anyway. If you want to clean the injection system, buy a diesel fuel additive with added detergency plus added lubricity (and not ATF).
Ron,
Have you tried different brands of fuel? Have you tried a fuel additive with a cetane improver? It might be late ignition of the fuel caused by low cetane. I don't know if your engine has any sort of device to adjust injection timing to get the best injection point so ignition begins promptly after the piston passes top dead center. If the fuel is late starting burning you'll get a noise somewhat like you describe. Higher cetane fuel starts burning sooner after injection--less ignition delay. There probably are other reasons for the combustion noise you hear, and a good diesel shop might be a big help. Try a fuel additive with detergents and cetane improver. Try a couple of doses following the label directions. If that doesn't help, see a pro.
trucker495
Linden, CA
Posted: 05/11/08 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
My advice is get it to a dealer or an authorized cummins dealer! You are burning the tops of your pistons and that ain't good!!
coolbreeze01
Redding, Ca
Posted: 05/11/08 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you are lugging your engine. I wouldn't add a magic additive, because there aren't any. Good luck.
2008 Dodge 3500 CTD LB SRW 4X4 6-Speed Auto
P3 Blue Ox Sway Pro
2007 Komfort 212
wcjeep
Tacoma, Wa
Posted: 05/11/08 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
Have you changed the fuel filter regularly? Have you checked the lift pump pressure? If it's the lift pump and you goto Dodge, they'll install the intank lift pump. According to Dodge, your 03' liftpump is no longer available. However, it's now available in the aftermarket at a cheaper price. In my opinion, the best option would be to go aftermarket lift pump with increased filtration (Fass, AirDog, etc).
Could also be the FCA. Fuel Control Actuator-about $100 from Cummins. Also, have your fuel tested.
LoudRam
New Jersey
Posted: 05/12/08 12:25am Link  |  Quote  |  Print  |  Notify Moderator
Check out Dodge Talk. It's one of the best forums around for Dodge trucks. I've been a member of it for years.
Todd
Desert Storm Vet (US Navy)
2002 Fleetwood Prowler Lynx 30'
2001 Dodge Ram 1500 Quad Cab 4X4 w/360 (not stock)
Predator DX2 brake controller
Equalizer Sway Control Hitch
If you can read this thank a teacher
If you can read this in english thank a vet
coobie
Jerome michigan
Posted: 05/12/08 03:31am Link  |  Quote  |  Print  |  Notify Moderator
Ron,
I disagree on the seafoam it states on the can for gas or diesel engines.I have run it before in my engine with a cetene booster(stanadyne Pf or primrose 405-409 additives) and it runs fine.coobie
2004 Dodge 2500 cummins turbo diesel 305/555 motor,auto tranny & 3.73 gears.Bullydog power pup with outlook monitor & afe stage 2 air intake and Fass fuel system.
LoudRam
New Jersey
Posted: 05/12/08 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
Ron,
Yep, It says it can be used in both gas and diesel. I've used it in my gas, intake, and oil to clean my truck out. The only thing it will do is foul your plugs, and obviously that's something you guys with the oil burners don't have to worry about.
