Daveg99
Dallas Texas
I am renting a starcraft 24' RBH travel trailer for memorial day weekend. I am towing it 240 miles one way on flat land through the middle of texas. My friend went and reserved it at the RV rental place so I havent seen it. I drive a 2005 crew cab F150 with four wheel drive and the 5.4 V8 motor. My truck is pre wired for the electric brakes but I do not have a brake controller. I am going to go to the rental place and see what this trailer has equiped on it as far as surge or electric brakes. If it has electric brakes should I install a brake controller?
Here is the picture of the trailer....
link to the 24' travel trailer
edited 05/11/08 12:54pm by Daveg99 *
2005 Ford F150 FX4 super crew
5.4 V8 3.73 gears
2.5" leveling kit
LAdams
Northern Illinois
Yes, more than likely it will have electric brakes so use a brake controller and also use a weight distributing hitch with some form of sway control too...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
** NEW ** blog.rv.net
lampooner
South Carolina
I have a Starcraft Star Stream 24QB. I am sure the trailer will have electric brakes. The rental place may supply a brake controller. In almost all if not all states it would be required to be legal. Your liability would be out-of-site without it. In an acident, the other party would own the rental place, you and anything you own!
You should not have any problem towing the trailer. For your limited tow and your tow vehicle, I would not bother with a weight distribution hitch. An anti-sway bar would also be a good idea to have installed. Should be around $100 dollars. Again the rental place may supply.
Lampooner
Remember you are only young once,
but you can be immature fotrever!
Daveg99
Dallas Texas
where can I get a weight distrubuting hitch with sway control? And how much is it going to cost. Sorry about the newbie questions.
JJBIRISH
BUTL;ER, PA, USA
I have never rented one, so it would only be a guess, but I would think it could be rented at the same time and may be required...
I doubt the rental company would accept the responsibility of sending you down the road without the required equipment...
by all means go there and discuss all of this with them before making the rental...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
Capn Courage
Ontario
I would contact the rental place to see if they have rental equipment available. You will need to have a weight distributing hitch, sway control and a brake controller, even though you are only travelling a short distance you can encounter a variety of scenarios that will make you glad you have the proper equipment, and it will make the trip safe and more enjoyable. If you had to go out and buy the required equipment you are probably looking at $500 to $600 dollars minimum.
Norm
Capn & Mrs. C
2004 Rockwood RLT23FB
2002 GMC Safari
Eaz-Lift W/D hitch
Reese Anti Sway
Hornet28BHDS
Parker, PA
You will more than likely need a brake controller and a Weight Distributing Hitch. Have fun on Memorial Day! I CANNOT wait!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
jims94vmx
allentown
hey dave, all are correct. you need a brake control. I would think the rental place would have all this stuff, especially if you aren't pulling normally? are you the same dave that used to frequent the f150 site? sure got boring there. always got a laugh at your fun times. have a safe trip! camping can be alot of fun....
jim
Daveg99
Dallas Texas
Yep thats me. I am still on there under a different name. My name was JimBeam for a while then that name got banned. Now I have a new name on there. The mods hate me there for some reason and I didn't even do anything. Oh well. I sent the rental guy an email and we will see what happens. I am going to go ahead and buy a electronic brake controller. The WD hitches are pretty pricey from what I have seen. Hopefully the guy has some for rent at his shop.
