I dewinterized my camper and used the tank pump and the water pressure was fine all on three faucets. Then I went to city and the bathroom pressure was fine, but the kitchen sink faucet was like a trickle…… I also traveled and rehooked to city water and the same thing. Any thoughts???
All bypass value we set correctly and all drain values(under the camper) were closed……
The strainer on mine often needs cleaning. If it's not that, are both the hot and cold water a trickle? If not, check the pipes to the faucet, if they both are slow the problem is with the faucet but that wouldn't explain why it is only with city water, unless something got lodged in the faucet after switching to city water. Is it still good if you switch back to camper water?
