RV.Net Open Roads Forum: Tech Issues: 12V question
 > 12V question
Jeff4au
Eufaula Alabama USA
Posted: 05/11/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
I am not getting 12v on somethings in my 5th wheel. The battery is fine and the landing gear and slides will work. The switch that shows the charge of the battery etc shows nothing... When the rig is pluged into shore power all of these things work even though they are 12V. The fuse box has 2 30 amp main fuses and both are good... any thoughts on what is going on??
2001 F250 V10 4x4 CC Lariat 3.73
2003 Keystone Challenger 32TKB 5er
Honda EU3000, Prodigy, RDS tool/tank combo
javaseuf
Southern Cal
Posted: 05/11/08 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like your battery isn't getting power to the convertor. Either a in-line fuse somewhere or the battery isn't charged or charging.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
Bobbo
Memphis, TN
Posted: 05/11/08 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds like you have a battery disconnect switch and it is disconnected.
Bobbo, Linda and the furry kid (German Shepherd)
'07 Winnebago Outlook 31C on a Ford E450 Super Duty Chassis
Near N35 12 17 W89 50 57
Jeff4au
Eufaula Alabama USA
Posted: 05/11/08 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
I am leaning towards the inline fuse. No idea where it would be though...Could a problem with the inverter cause this or would that be just the opposite of what is happening?
Road Runners
Tampa Bay, Florida
Posted: 05/11/08 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
I would think that you have a fuse blown somewhere. Are you sure there are only two fuses. My DC fuse box on my fiver has about ten fuses for various circuits. I would think that you must have a fuse box somewhere that you don't know about yet.
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
Jeff4au
Eufaula Alabama USA
Posted: 05/12/08 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
I tested the battery with both cables off of it and it read 12.60v. I then plugged into shore power and tested the positive cable and a ground and it read 13.73v. So I am assuming that is the charger working which tell me the wiring is ok from the charger/inverter to the batter. So why no 12v when the shore power is not plugged in??
Road Runners
Tampa Bay, Florida
Posted: 05/13/08 11:00am Link  |  Quote  |  Print  |  Notify Moderator
It seems to me that there is a fuse in the line that runs from the batteries to the fuse box. Perhaps that is blown...
 > 12V question
