Daveg99
Dallas Texas
This is the harness I am getting. From what I understand it will be a plug and play install on my 2005 F150 FX4.
http://www.rvwholesalers.com/catalog/product.php?productid=1950
This is the controller....
http://www.rvwholesalers.com/catalog/product.php?productid=60
I notice this controller does not have the sliding lever like most do. I am assuming this thing is totally automatic. That sure makes things easy. Especially for a Newbie to towing trailers. What do you guys think?
2005 Ford F150 FX4 super crew
5.4 V8 3.73 gears
2.5" leveling kit
Cool Canuck
Winnipeg, MB, Canada
Daveg99 wrote: I notice this controller does not have the sliding lever like most do. I am assuming this thing is totally automatic. That sure makes things easy. Especially for a Newbie to towing trailers. What do you guys think? Actually it does have a sliding lever. It is underneath. You might have miss read the ad. "With Prodigy no manual level adjustment is necessary.
00 Jayco Eagle 313 5th
01 F250 PSD S/C S/B
Daveg99
Dallas Texas
ahhhhh. Ok. but this thing looks like the easiest one to install and use as far as brake controllers go.
tvman44
Southwest Louisiana
I've heard it is aggod controller, I have the P3.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Kennedycamper
Algoa, Texas
I have used a Prodigy for over 5K mi towing different trailers. It's a great brake controller. I have heard the P3 is the same with more diagnostics built in.
Cool Canuck
Daveg99 wrote: ahhhhh. Ok. but this thing looks like the easiest one to install and use as far as brake controllers go. Yep. Pretty much plug and play. Good controller.
no_bytes
Wisconsin
Yep, just plug and play on my 2000 F150.
If you have the trailer package on your truck already, it should be a simple plug-in. I'm not sure how the 2005 FX4 come. On mine I also had to add the brake fuse under the hood, the fuse came with the truck, I just had to plug it in under the hood, yours probably already has that fuse plugged in.
b_salgado
Salisbury ,NC,USA
Great controller. It is a plug and play deal on your truck. It will take you all of 15 min to install. I have had no problems with mine in over 5000 miles and love the way it operates. Enjoy!
04 Lariat Supercrew 4x4,5.4,3.73, Edge tuner, flowmaster duals
06 Trail Bay 31BH, nicely optioned
Equal-i-zer
Prodigy
Follow vehicle, 05 KIA Sorento EX for the golden retrievers.
NHguy
NH
If your truck came with trailer tow package as mine did you can find the truck end of that connector just under the left dash. I remember installing a relay as well, I believe that is for the battery charge line. I'll look at the paperwork in the AM and repost. In my 05 the relay and pigtail came in the glove box from the factory. I added an extra ground to the battery this year because of weak brakes, that made a ton of difference in braking power. Before the ground I was near maximum power on my controller, and not getting great stops. Now it stops great.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, XM Cradle, Battery Disconnect
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
dodge guy
Chicago, western subs.
Graet controller, the majority of us here use it!
Wife kim
Son brandon 6yrs
Daughter marissa 5yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
