RV.Net Open Roads Forum: Beginning RVing: 1st Trip Done !!
 > 1st Trip Done !!
Furter69
Palmerton,PA
Posted: 05/12/08 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Our first ever trip in the 5er is over and all went fairly well for ROOKIES. Left Friday morning for Knoeble's campground in Elysburg,PA. Except for some heavy rain here and there no problems. Pulled up to the water fill area and couldn't understand why my fresh tank wasn't getting full till I realized I attached the hose to the city water outlet. Backed into site with no problem.
Now I have a question. I have 3 valves next to the water heater and I had all 3 open to de-winterize. When I tried to run the hot water it kept switching from hot to cold and never sustained the hot water. My buddy who traveled with us also had the same problem but he figured his out by closing the valve in the middle. I was going to try this but then my DW yelled to me that we were out of water. I guess in all my trouble shooting and 2 showers and not pumping the water through the water heater and lines and not topping off the water after all this,we ran out.. LESSON LEARNED.
I hope this is the worst thing that ever happens but I am fairly sure it won't be.
Fuel mileage on trip was 10 MPG going and 9.5 coming home.
Any more info on my water problem is greatly appreciated.
Thank You all for your postings !
Frank
2006 Jayco Eagle 281 RL
2008 Ford 250 SB
Reese Slider 16,000
ljr
Pennsylvania
Posted: 05/12/08 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
The middle valve is the bypass. With it open and the other two close,d you can fill the pipes with antifreeze without wasting a bunch filling the heater. In normal use the middle is closed and the others are open.
Larry
goin2themountains
Aztec, NM
Posted: 05/15/08 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Congrats on your first trip, and many more to come.
Puller: '04 HD2500 4x4 SB,EC Duramax/Allison. Airaid intake, 4in. exhaust turbo back, ORU leveler.
Pullee: '02 Keystone Cougar 276EFS Reese 16k w/ slider.
(map is for current 5er only)
Hornet28BHDS
Parker, PA
Posted: 05/15/08 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Glad it went well! Enjoy your new 5er!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
 > 1st Trip Done !!
