RV.Net Open Roads Forum: Tech Issues: stabilizers and Weight
 > stabilizers and Weight
JayflightG2
Vancouver
Posted: 05/12/08 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
Hey Guys,
I need to adjust the leveling of the TT and I am curious if it is safe to put the entire load on the stabilizers for less than a minute while I toss under the tongue jack more blocks?
Basically bring up the tongue jack, slip under more blocks then put the tongue jack down to take the weight off the stabilizers.
2008 F350 Super Crew Lariat Diesel
2008 Jayco Jayflight G2 29FBS
1200 lb Draw-Tite Trunnion WD & Dual Cam
taxgod4u
Bay Area, CA
Posted: 05/12/08 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
You will bend the rear stabs or rip the sheet metal screws holdign them to the frame out.
All things in moderation, except acceleration!
Zip ties, the duct tape of the new milenia!
2001 F250 Powersmoke turbo diesel, 3.73LS
Crew Cab, SRW, SB, 6 inch lift, Single 28 inch semi airhorn underneath! SCMT, A Pillar mounted, Pyro, boost and Trans gauges.
2005 Wildcat 29RLBS, Prodigy, 2 EU2000i's Draw Tite 18K Signature Series, front receiver, on board air, Airlift HD airbags
2003 Ford Explorer XLT 4X4, V8, 5sp AT, 3.73LS
2003 Ford Explorer Eddie Bower 4X4, V8 5sp AT, 3.73LS, Dual semi air horns underneath
2002 XR50, PW50
fla-gypsy
North Florida
Posted: 05/12/08 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
No, it is not OK
05 Super Duty XLT CC 5.4/3.73 5 sp auto Torqshift
06 Keystone Hornet 29 RLS/(The"Cracker Cabana")
Reese HP Dual Cam
Camping Photos
Northeast Florida Camping Club
St Andrews SP cult member
Dixonmatco
Santa Rosa, California
Posted: 05/12/08 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
I do it all the time with no problems. I have a very heavy duty frame under my TT, and the scissor type stab jacks rated at 3000 lbs each. Many do not..Depends on your TT. Better check your owners manual or with the Manufacturer.
If my electric tongue jack does not go high enough to get level, I run it almost as high as it will go, crank down the front stab jacks, run the tongue jack back a bit, add a block or two and raise the TT to level. Then I reset the front stab jacks properly. I keep the rear ones up until the TT is level, so they have no effect.
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
ShapeShifter
Buffalo, NY
Posted: 05/12/08 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Not a TT, but I've had a similar situation with a cargo trailer, which had no stab jacks. When the tongue jack couldn't raise things high enough, I cranked it as far as it would go, then I put a firewood log vertically under the A-frame next to the jack as temporary blocking, and retracted the tongue jack. Then I put blocks under the tongue jack, and cranked up some more.
Maybe something like that might be safer than overstressing the stab jacks? Just make sure the trailer is chocked securely, and the temporary blocking is stable. You should use something more secure than a log (like I did) as any side load on the tongue could cause it to fall.
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
Chuck&Gail
In the Colorado Mountains
Posted: 05/12/08 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
NO it is NOT. Why not hook up to TV?
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 4 Canada Provinces, & 2 Territories.
LAdams
Northern Illinois
Posted: 05/12/08 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it is OK assuming they are BAL... BAL rates them at #5000-#7500 each depending on model... Just make sure your on flat, level ground so the TT does not rock back on them and bend either their sheet metal or the TT frame or sheet metal mounting... I routinely hold up the front of my #9400 TT with them and they don't even strain or groan...
Here's the link to the specs:
http://norcoind.com/bal/products/consume........ling_products/levelingscissorsjack.shtml
And here's the specs:
Leveling jacks provide leveling and stabilizing for travel trailers and fifth wheels. Two models extend from 4" to 23-3/4", and one model extends to 30". Given the broad range of ground-to-frame clearance, there's a BAL leveling jack for almost every RV.
The Deluxe Leveling Jack includes a patented roller-bearing assembly for smooth and easy screw operation.
The Standard Leveling Jack provides a sandwich construction bearing design to assist in screw operation.
Tooth gear design of the scissor arms ensures straight line vertical extension and retraction.
Double lead, acme thread drive screw is designed so the jack raises quickly and the crank handle turns easily.
When placed in the handle receiver, the crank handle can be easily rotated, even when tilted.
Rust-inhibitive E-coating on the jack and shiny zinc coating on the crank handle ensure long life.
Mounting hardware is included; jacks may be welded to trailer frame.
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
** NEW ** blog.rv.net
JayflightG2
Vancouver
Posted: 05/12/08 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure what you mean by hooking it up to the TV? I am trying to level it on my driveway so I can run my fridge
JayflightG2
Vancouver
Posted: 05/12/08 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for your input LAdams. However, my driveway is (unfortunately) not flat and on a slight slope See Here Is it still possible to do as you suggest? I was thinking of putting some car jacks to help out with the weight. What do you think?
Dixonmatco
Posted: 05/12/08 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
LAdams.. Those are exactly what I have on my Komfort. They came standard equipment. Along with a frame that is built like a tank.
That combination is why I can get away with it, where many lightweight trailers with lighter frames and Stab jacks might be damaged doing this.
JayflightG2 My driveway looks like that also.. I really make sure that the wheels are double chocked (Bal Deluxe and regular truck wheel chocks) before I do it.
