CT Camper 313
Manchester, CT
Hi Everyone,
This is probably a question asked many times, but how can I keep my black water tank squeaky clean, and stop "things" from clogging? We are stationary - so no towing, so the tank contents doesn't get jiggled around. When the honey wagon comes to pump us out, there always seems to be a problem. I fill up with water before they come, but then they always tell me it's empty -- even though the sensors say no; and sometimes I can see (with a flashlight down the toilet) that the sensors are correct!
I tried adding calgon water softener once, but it made the tank give off a horrible odor so I never did it again (YUCK).
Any help would be greatly appreciated. I guess I need to know if there's any secrets to making the contents turn to liquid more quickly, or to making the sides of the tank repel the nasty stuff. (do use the deordizer stuff)
Thanks very much,
Doreen
geurk
Kentucky
I've heard great things about the Flush King from other owners, especially how it gets the sensors working again. I just recently bought one myself and was amazed that after dumping the tank and then using the Flush King, how much cleaner it got the tank.
Gerry and Michelle
4 kids ages 9,8,6, and 4
2008 Keystone Cougar xLite 29BHS
2003 Chevrolet Suburban Z71
2002 Toyota 4Runner Limited
2005 Sea Ray 220 Select
2008 Kawasaki Jet Ski Ultra 250x
Mandalay Parr
Phoenix, AZ
Try putting in the black tank chemicals. They always work for me. Most sensors do not work.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
CT Camper 313
Manchester, CT
Hi again,
Thanks, I do put in chemicals, but it seems that they don't do the job completely. Can you recommend a certain brand?
Also, if I use the "flush king" thingy, is it something that the campground pump-truck will use, since they're the ones doing the actual pumping? Is it something they hook up to that is already on my TT?
Someone at the campground told me to use olive oil, and that it would make the walls of the tank slippery so nothing would stick, but I'm a little leary of the smell that it might produce.
Doreen
Hornet28BHDS
Parker, PA
You need a Tornado Tank Rinser.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
windriderjr
Massachusetts
Flush King is used to backflush the tank when it is being dumped. Not something a dumping service is likely to do for you.
The tank rinsers will probably be a better alternative for you.
DW and I in our Gulfstream Amerilite 21MB
Chevy Silverado 2500 HD - Duramax Diesel 6.6L - Allison Tranny
"We can categorically state that we have not released man-eating badgers into the area." - Major Mike Shearer - British Army - Basra, Iraq
old guy
Oregon (pronounced Or e gun)
tornado or quickie flush. works great best things on the market to clean out a black tank.
GSS0816
Chestertown MD
I use the quickie flush...works great.
davidj54
South Alabama
How often do they pump you out? are you seeing liquid or solids when you peer into the tank? If it's solids you need to break it up using whatever means required immediately after they've pumped you out. If it's liquid i'd suspect they're not emptying it 100%. They may be closing the valve before a full drain. As far as it needing to be spotless, there's no need for that. Just make sure you don't create a brown mountain.
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
MFinCA
San Francisco Bay Area, CA
CT Camper 313 wrote: Someone at the campground told me to use olive oil, and that it would make the walls of the tank slippery so nothing would stick, but I'm a little leary of the smell that it might produce.
As others have pointed out, you might be best served by using the Tornado Flush: Tornado Flush
As far as making the tank walls slippery, many of us have found that the GEO Method works pretty well: GEO Method
I'd first try the GEO Method and see if that worked.
MFinCA
2004 Homestead Settler 255RS
1999 Chevrolet Suburban 2500
