RV.Net Open Roads Forum: Fifth-Wheels: Water damage to insulation
 > Water damage to insulation
jjfay03
Washington State
Posted: 05/12/08 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
So I was done getting the camper unwinterized and was heading into the house for supper, and being tired from the day I forgot to unhook the hose from the camper and the house but I did turn it off. We'll my oldest son came running in the house and said that he found the leak in the camper?? Puzzled because I had already found the leak, he said that there was water running out of the downstairs storage compartment. So it appears that my 4 yr old thought that he was going to help daddy with the camper and turned on the facuet and left it on. So I got that cleaned up, not to bad because we caught it right away, or so I thought. Today while I am at work, DW calls and said that the camper is leaking water again from underneath the camper. Yes, I forgot to check the underneath belly :-( So took out all the insulation, if you can call it that, it looked more like padding for a quilt. After all of this my question is:
Can I replace that insulation with regular house insulation like R-13 or something else? or do I have to use some sort of special insulation designed for RV's? Sorry for the long post, but we all got quite a chuckle out of this. John
John and Jeannine + 3 Boys 9, 6, and 4.
2007 Dodge 2500, 5.9 CTD LB, Husky Brake Controller,
Husky 20K Hitch, Linex, and Firestone Airbags, Pac Brake.
2007 Keystone Challenger 34' SBH 5er
I can't forget the puppy, Little Boy!
mt-pocket
Minnesota
Posted: 05/12/08 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
I would use closed cell styrofoam (the pink stuff) as thick as whatever will fit in the space that is available. Make sure all of your wood dries out real well or you might have problems with that later on. If the styrofoam will be exposed you might want to protect it with some tyvek (?). You can get all of it at Home Depot or Lowes. Good Luck.
Gary
One Wife, No Money, Retired
2006 2500HD Chevy Silverado Duramax,
2006 Americana 35/36 5th Wheel
Pressure Pro TMS, Huskey Hitch 16K
tom_kat
way upstate new york/lake george area
Posted: 05/12/08 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
you can use regular house insulation but foam gives you more r value per inch and water doesnt soak into it like the fiberglass stuff.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
cm
Dillon, CO USA
Posted: 05/12/08 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
The closed cell foam he is describing is called extruded polystyrene. It is different than expanded polystyrene - bead board
- which the usual foam insulation used by RV manufacturers.
But there is no such thing as pink styrofaom. Styrofoam is a brand name not a generic term. The Dow Chemical Co produces the Styrofaom brand of extruded polystyrene and their marketing color is blue. If you see a foam insulation that is pink it is produced by the Owens Corning company.
In my area the Home Depots do not sell the Styrofoam brand they sell the pink Owens Corning brand. The Lowes stores sell the Styrofoam brand.
