RV.Net Open Roads Forum: Travel Trailers: Dometic Auto Temp frost
 > Dometic Auto Temp frost
Capvin
Hutchinson Island, Florida
Posted: 05/12/08 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
My refrigerator (a Dometic Auto Temperature) has begun to get ice on the fins. It seems like it had formed water droplets that then froze. The temperature in both the freezer and fridge are fine and the door seals are perfect. I am staying in the Florida Keys this month and it has been hot during the day but I do try to not keep the door open too long. Any reason to be concerned about this? Don
2005 Silverado 2500HD
2008 Surveyor Sport 186
Phils
Paradise, CA
Posted: 05/12/08 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
That's normal. Defrost when it starts toget thick as it'll cut performance and increase propane use.
Phil
'91 K2500 and '01 Komfort 27FS
Off the grid and outta sight at home
Go camping to have neighbors and amenities
NHguy
NH
Posted: 05/12/08 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Yup, true. RV refrigerators are not frost free like at home.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, XM Cradle, Battery Disconnect
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
Diabs
Toronto, Ontario
Posted: 05/12/08 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
I noticed the same problem when I was in Sugarloaf. The heat was working my fridge over big time! I found leaving my A/C on during the day to keep the inside temp bearable, helped the fridge from working to hard.
Also thought about getting a little fan to help blow out the hot air in the back of the fridge area....I guess were the cooling fins are. I hear that helps aswell in very hot weather....
Mandalay Parr
Phoenix, AZ
Posted: 05/12/08 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Try raising the temp one notch. Mine cleared up.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
jeanspach
New Mexico
Posted: 05/12/08 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Mine has a humidity switch that helps keep frost from building up. Beware, however that this feature runs all the time on the 12V when switched on and draws significant current and can drain your battery as it has mine.
Joel, Leesa, & Lakota (bed-hogging-dobie)
2001 F-150 SuperCrew Lariat Offroad 4x4 5.4L 4.10 LSD Tow Package
2005 Trail-Lite 8308S 5,162# dry
Fulltimers
Anywhere, USA
Posted: 05/12/08 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
If you are in a humid area, such as Florida, moist air will enter the fridge every time you open it then condense on the fins. The fins usually run at or below freezing so it will freeze.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2001 Saturn SC2 (Mr. Toad
Photos
