SoCalRailFan
Riverside, CA
Was curious if anyone with a Westlake has sway issues. If I go above 58 mph I can start seeing the rear of the trailer move back and forth, very unnerving. I've loaded what I can in front of the trailer tires. The trailer sits very level with my Jeep or slight down in the front.
So if you have a Westlake would love to hear how yours performs. Here's a shot of the trailer and Jeep from this morning showing how it sits.
edited 05/12/08 06:55pm by SoCalRailFan *
Thanks,
Dave
www.SoCalRailFan.com
2006 Jeep Wrangler Umilimited, 2008 Fleetwood Westlake
skipnchar
Topeka Kansas USA
It would be pretty simple to add a friction anti sway bar to stiffen the connection. Pop ups aren't subject to wind issues like travel trailers and passing trucks don't effect them much but single axle trailers are more prone to sway than duel axle models.
bugdude
SoCalRailFan wrote: Was curious if anyone with a Westlake has sway issues
Yes! We have an '07 Westlake and did have some issues with sway even with a friction sway control installed. Could not imagine how bad it would have been without the sway control!
to help with this problem on the return trip home I repositioned the stuff we had packed onto the floor in the trailer. I moved the heavier stuff to the front and the lighter stuff to the rear.
Doing this made a huge difference.
Give this a try and see if it helps!
Nights camped in '06 2
Nights camped in '07 11
Nights camped in '08 0 for now
the hangman
Green Bay, Wi
I suggest you weigh the popup and the tongue. Without those numbers - everyone is just guessing
Jeff
2005 Fleetwood Valor
2007 Nissan Pathfinder
dodge guy
Chicago, western subs.
How are the tires wearing? it is possible you have a bent axle giving you a slight toe in/out condition! just a thought.
Wife kim
Son brandon 6yrs
Daughter marissa 5yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
bud121156
Shelby, North Carolina
Good investment!
camsa5
Canada
Since your air conditioner sits behind the rear axle, it may be acting as a counter weight to your tongue weight causing it to be lighter up front. Maybe not but worth a thought.
- 2004 Chevy Astro
- 2007 1272ST Coachmen Clipper
- Equal-i-zer 600
- Me, Wife & 5 kids
scpopupcamper
Lugoff, SC, USA
camsa5 wrote: Since your air conditioner sits behind the rear axle, it may be acting as a counter weight to your tongue weight causing it to be lighter up front. Maybe not but worth a thought.
agreed
Martin Ray
MrPressure
FYI, Tow vehicle!
hujorgan1
North Carolina
I have a 2000 Westlake and thought I was going to end up in a ditch bringing it home from where I bought it last fall. The axle is too far forward - not nearly enough tongue weight. Two suggestions:
1) keep the low tongue weight in mind when packing, and put the heavy stuff up front, and more importantly,
2) get a sway bar. The sway bar made all the difference in the world - doesn't even try to sway anymore.
2000 Coleman Westlake
2005 Tundra DC
