RV.Net Open Roads Forum: Tow Vehicles: RDS Fuel Tanks
Search only in Tow Vehicles
 > RDS Fuel Tanks
Gatorkade
Williamston, SC
Posted: 05/12/08 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
What prevents these gravity feed tanks from overflowing the OEM tank?
Is overflowing a problem?
Peg Leg
Anderson, IN
Posted: 05/12/08 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
A gravity feed will overflow the OEM tank if left on.
Mine has a manual ball shut off valve and then a 12 volt electric solenoid valve. If I'm traveling I turn on the manual valve and use the electric valve as needed. If the key is off the electric valve is off, but I still turn off the manual valve when not traveling.
KA9ATV
K2500 7.4 3.73
Michelin 245/70R19.5 XDS2 on Vision Type 81's
31' Dutchmen
Yamaha EF3000iSE
retired gadgetman
jimtoo
Now, Ultra Perfect
Posted: 05/13/08 09:38am Link  |  Quote  |  Print  |  Notify Moderator
If the tank is installed using the RDS fittings to tap into the filler neck it will not overflow. The filler neck of the original tank is cut and a splicer or adapter is installed, this will have a fitting with a small float, this must be installed on the top side of the neck, it will shut off the inbed tank when the level of fuel gets up and into the filler neck hose. It is installed below the level of the original fuel filler cap, so the level of fuel does not get as high in the neck as the filler cap.
I have had mine for over 3 years now and it works great. The only time it gives me a problem is if I have a senior moment and leave it on over night, I use a manual valve, and it fills my factory tank, then I drive for a while with it still on, the fuel gage does not move off of full and the onboard computer thinks something is wrong with fuel gage and will turn on light on dash to check fuel gage. I simply shut fuel valve off and continue to drive and when gage moves off of full the light will reset.
Happy Camping
Drive Safe
Jim & Bette
Kerrville Sweetheart VI Rally
George West Storyfest
04 GMC 3500, CC,Dually,Duramax,Allison
CB Radio, Prodigy, Turboliner, Ride Rites
08 Bighorn by Heartland, 3055RL, Trailair Pinbox, Equaflex.
jason_rving
North Georgia
Posted: 05/13/08 10:58am Link  |  Quote  |  Print  |  Notify Moderator
A $2 egg timer from wal-mart keeps mine from overflowing. I set it to 35 minutes and when it rings the tank is full enough for me to turn off the pump. Once my 48 gallon RDS tank is that low it will not self siphon.
Jason and family
2004 Cedar Creek 31LBHBS
2004 2500HD Silverado CC LT LLY Duramax/Allison 4x4
48 Gal Aux Fuel Tank - 74 total gal cap.
Husky 16K, Kipor 3500ti Generator
Prodigy, Timbrens, 285 Goodyears, Rhino Lined,
Cobra 75WXST with Firestik
JOHNL
JERMYN, PA, LACKAWANNA
Posted: 05/13/08 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
I just ordered a RDS tank today.A 91 gal with a tool box. It will cost more to fill it up than the tank cost.
MichaelC
Vancouver, Washington
Posted: 05/13/08 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
I have the 91 gal RDS tank with the gravity valve and have never shut the valve off. The valve needs to be installed as horizontal as possible.
2008 Ford F-450 King Ranch
2000 SE102 Snowbird 34+2
Dave H M
IL
Posted: 05/13/08 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
I got one that works flawlessly also. It is amazing that you will get posts that don't have an idea of how the system works.
When i have senior moments and leave mine on for dasys it will never overflow.
The instructions come with the gravity kit from RDS.
BTW, gravity is something it seems no one has figured out how to charge me for.
That shut off valve also functins as the anti roll over valve.
Chabby 2
Gahanna, Ohio
Posted: 05/13/08 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
I have an RDS 51 gal. tool box combo and used their installation kit in my 04 GMC D/A. The first night that I left the tank valve on it filled up my OEM tank and then washed my driveway with diesel. RDS reply was that "some" trucks have a breather/vent in the OEM tank and it will indeed leak fuel when the OEM tank is full with the RDS tank valve is open. It would have been nice to have this information before hand from RDS but it is nowhere to be found on their website or in their literatrue. If I had known this maybe I would have spent the extra money and purchased a Transfer Flow.
FiverBob
Sarasota, Florida USA
Posted: 05/14/08 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
My RDS is gravity fed before they even had the kit. I have left the valve open many times with no problems. The cap vents one way - - in. Love it and I love the extra money in my bank account from other tanks. Nothing to break, burn up or stick.
2003 Dodge 3500 HO dually 6 speed Laramie, Jordan Controller, RDS aux tank/tool box, Bremen boards, RamAirIII, Jacobs EBrake, Air Safe 25K hitch
Carriage 36' Triple slide Fiver, Onan Gen, Sat, Prosine Inv., MORryd IS and pinbox
sirdrakejr
Las Vegas, Nevada
Posted: 05/14/08 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from 5th wheels to tow vehicles.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
 > RDS Fuel Tanks
