RV.Net Open Roads Forum: Travel Trailers: How to winterize a keystone cougar 304bhs?
 > How to winterize a keystone cougar 304bhs?
scottcougar
Saskatchewan
Posted: 05/12/08 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
On my c-19 hybrid i had a seperate line by fresh tank with ball valve. i could toggle between fresh water or run plumbing antifreze into hose by toggling valve. how do i do it on my 2008 304bhs? I found the pump but lines are fixed? do i remove suction line off pump and get some hose? Or can i draw it in from low drain lines? How without getting antifreze in fresh water?
downtheroad
Tumbling Waters, Washington
Posted: 05/12/08 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
Gosh Scott,
It's May... what's all this talk about winterizing?
Winter? I don't want to hear another word about winter....lol
GMC Duramax/Allison (LBZ)
08 Komfort 277TS Our Rig Pic
Reese Dual Cam HP
scottcougar
Saskatchewan
Posted: 05/12/08 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
lol. but really. does any1 here have to remove suction line off of pump?
SuperDutyMan
Western PA.
Posted: 05/12/08 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
I need to know the same thing............in November...when you get an answer PM me ....in October LOL!
2008 Keystone Cougar XLite 29RLS
2006 Super Duty V10 6 Speed 4.10S Tow Command Tow Pkg. 4X4
sprinterowner
tyngsboro,ma
Posted: 05/13/08 05:17am Link  |  Quote  |  Print  |  Notify Moderator
If you had this camper this past winter.(according to your previous posts)Why would you be asking this question in May.Just a thought.
Keystone Sprinter 311 BHS
2007 Silverado 2500HD "classic" CC Duramax/Allison Greystone metallic
LeeShearer
Royersford, PA
Posted: 05/13/08 05:20am Link  |  Quote  |  Print  |  Notify Moderator
You can buy the winterizing kit that was installed on the c-19. It includes the 3 way valve and the short hose to the antifreeze bottle.
2005 Fleetwood Resort EXT 25SB
1999 Chevy K3500 short bed dually
scottcougar
Saskatchewan
Posted: 05/13/08 05:33am Link  |  Quote  |  Print  |  Notify Moderator
i bought camper late fall (november of 2007).its a 2008 cougar 304bhs. it was winterized for me. i have a few months yet but was just wondering. Theres a compartment under the bath tub area that i will look into yet.
sprinterowner
tyngsboro,ma
Posted: 05/13/08 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Ok i get it now.I have a keystone sprinter and mine does not have the winterizing by-pass.i have to put the antifreeze in the fresh water tank and use the pump.I dont drink CG tap water anyway so its no big deal.I flush the tank real good when i de-winterize it .
Hornet28BHDS
Parker, PA
Posted: 05/13/08 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
Our Hornet came with a bypass kit.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
sprinterowner
tyngsboro,ma
Posted: 05/13/08 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
congratulations to you
