RV.Net Open Roads Forum: Travel Trailers: Rotation of TT Tires
 > Rotation of TT Tires
jtslj
Salt Lake City UT
Posted: 05/13/08 06:29am Link  |  Quote  |  Print  |  Notify Moderator
how often do the tires on my TT need to be rotated and how do you go about rotating them if you do?
when my FIL was helping me unwinterize the trailer he looked at the tires and recomend that I rotate them before too long.
What is your opinion. I am not sure the brand but I know they are brand new (last year) ST Tires.
1996 Chevrolet Suburban 2500 4x4 Vortec 5700
1987 Terry Tarus 29 R
troll3193
SouthWest, MI USA
Posted: 05/13/08 06:37am Link  |  Quote  |  Print  |  Notify Moderator
I rotate them when I do my bearings.. so every couple of years..
i have a heavy corner so it helps even out the wear..
Bryan
2006 RAM 3500 MegaCab w/Cummins Turbo Diesel
Mopar Exhaust Brake
2004 Dutchemen 31BK
nny12972
NY
Posted: 05/13/08 06:53am Link  |  Quote  |  Print  |  Notify Moderator
You might want to consider weighing your rig and double-check that you're towing it close to level and with tires properly inflated......if your F-I-L can see abnormal tire wear, it's ABNORMAL!
J
Dick_B
Palos Heights, IL USA
Posted: 05/13/08 07:11am Link  |  Quote  |  Print  |  Notify Moderator
You could do a search on this Forum for `rotate tires' where there are 76 replies; including mine.
I carry two spares, one in each left and right storage compartment. At the end of the season I rotate ALL tires counterclockwise (looking down from the sky) so the spares are used. (That's a whole seperate subject)
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Kenneth
Washington, the state
Posted: 05/13/08 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Only rotate if you have uneven wear or want to get service out of the spare. Othewise, what's the point?
If you have uneven wear, find and fix the problem.
NHguy
NH
Posted: 05/13/08 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
If you are like most people you'll nvere run them far enough to need rotating. Rotation is to equalize uneven tread wear and get all the miles from the tires. Trailer tires rarely/never wear out they just get old and dry out.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, XM Cradle, Battery Disconnect
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
Rogue42
Indiana
Posted: 05/13/08 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
Rotation may not be much benefit but I had the locat tire shop balance the tires and then rotate them as they were putting them back on. Seemed to ride smoother.
SuperDutyMan
Western PA.
Posted: 05/13/08 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
On the TV or a car the front tires will wear differently than rear because of steering,on a TT they just follow each other the same way,they should all wear the same if everything is right,so it's really not nesessary,but it wouldn't hurt a thing if you wanted to rotate them.
2008 Keystone Cougar XLite 29RLS
2006 Super Duty V10 6 Speed 4.10S Tow Command Tow Pkg. 4X4
Chuck&Gail
In the Colorado Mountains
Posted: 05/13/08 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
We don't rotate ours. Don't run them over 7 years either. Do use metal valve stems, and get them balanced, when I replace tires.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 4 Canada Provinces, & 2 Territories.
