RV.Net Open Roads Forum: Class A Motorhomes: painting faded decals
 > painting faded decals
hwybnb
Posted: 05/13/08 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
Ron Butler wrote:
... my Winnibago Brave isn't gelcoated, the one thing I wish it had! Will that procedure and products still work on my non-gelcoated sides?
What type of paint should I use to repaint the areas of the old decals?
The removal methods will work fine on non-coated fiberglass. As to the paint, automobile paint would probably be best for appearance and long life.
liveneasy
U.S./Mexico
Posted: 05/13/08 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
I've said it before... but everyone wants to keep using sprays, heat guns and scrapers to remove decals and stripes. If you want a quick, easy and foolproof way to remove stripes and decals, pickup a 3m eraser wheel. It fits on a drill and will completely remove a stripe, decal and the adhesive no matter how long it's been on the RV or what condition the stripes are in.
I have used them to completely remove the stripes and decals from 2 RV's. It's what the paint and body shops use... does the job quick, easy and doesn't damage the paint, fiberglass or metal thats under the stripes. I bought mine at a local auto parts shop for around $25.
Give it a try and you'll never use any other method again.
Greg
'96 Holiday Rambler Endeavor DP/'03 4wd tracker
Datastorm F1/D2/7000/on SatMx5
See where I am today
olfarmer
Iowa
Posted: 05/13/08 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
I Painted over a 3" stripe on mine 3 years ago it still looks good with no peeling or flaking. I cleaned the area with prep solvent I got from a parts store and masked it off. I can't remember for sure but I think I put a coat of primer on it and then 3 coats of acrylic enamel. If you look closely you can see some old cracks in the old stripes but it is not a glaring defect, sure looks better than the old cracked and faded stripe did and has a nice shine. I wondered if it would hold up but so far I am very happy with it. My stripes were not peeling just faded and starting to crack. I have some more that are starting to look old and am planning to do the same thing to them.
Good Luck on your project!
Ed
Beknet
Alaska
Posted: 05/14/08 01:43am Link  |  Quote  |  Print  |  Notify Moderator
Rachel's dad wrote:
What will Goo-Gone do to the fiberglass if you try to use it to remove any excess adhesive?
Someone told me that using a eraser would work ??
[b]Beknet:C
Note: Due to invalid formatting, all formatting has been ignored.
zoondoggie
Napa
Posted: 05/14/08 02:34am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info
Cheers
"If you don't know where you're going, you'll wind up somewhere else"
Yogi Berra
dougbo
Minneapolis, MN
Posted: 05/14/08 06:16am Link  |  Quote  |  Print  |  Notify Moderator
Tthanks for all the info. You all have been very helpful. Doug
50pascals
rochester, ny
Posted: 05/14/08 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry for non-clickable link.
There's another 3m eraser disc link in my reply as well.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/21096172/gotomsg/21099040.cfm#21099040
oldusedbear
Brookings, OR, USA
Posted: 05/14/08 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
I sorta kinda got into some of the issues discussed above. Recently downsized from a DP to a little 23 foot Coach House Class C, B plus, or whatever you choose to call it. Anyhow, most of the decals and some of the striping were in pretty bad shape. Fading, peeling etc. Additionally, the fiberglass gelcoat had gotten to the point where it just wouldn't respond to cleaning, waxing, buffing and so on.
So I ended up removing a lot of decals, and a fair amount of striping. It had too many "swirly" decals to suit my conservative nature, so I opted to leave some of them off, but to add some new striping over and above the stripes I was already replacing.
First however, I had to deal with the fiberglass. After considerable research, I decided to go with a product called PoliGlow. Long story short, it worked very well and has restored the gelcoat shine. Took me weeks instead of hours as claimed in the ads tho. Just a lot of work AND learning.
Finished it off with some 3M striping (bring money - 50 bucks a roll BUT a superior product).
So after a reasonably modest investment in money, and a big investment in time, I think it looks pretty nice. It is a "cleaner" look without the extra decals - - I coulda bought new factory decals, but they were about a 1000 bucks - - so I passed on that.
Anyone curious about the results can PM me for pictures if interested.
The reason for spelling is so that all of the words don't look the same.
engr4fun
Escondido,CA,USA
Posted: 05/15/08 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
I repainted my old rv stripes 3 parallel stripes.
Looked into removal replacement stripes.
Paid approx $100 is paint and supplies Used automotive spray paint from Pepboys. taped edges, sanded vinyl stripe, primed, painted clearcoated. It has been 3 years and looks great.
really did not take that long.
Weldon Crew
John,Myra,Evan,Eric+2dogs
2005 Fleetwood Flair 34F 3 Slides W22&8.1L
Weekends+Any Chance We Get
