RV.Net Open Roads Forum: Travel Trailers: Water hookup on rear of trailer
 > Water hookup on rear of trailer
The Dude Dad
Simi Valley, CA
Posted: 05/13/08 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
We've been looking at trading in our current unit and found the Tango. Seems to be very well built and has received lots of praise on here (yes I did a search. yay for me ). I noticed it had the water hookup on the very rear of the unit pretty much underneath the license plate. I personally had never seen that before. It is separated a bit from the dump valves and the electric hookup. Our current trailer has all the hookups fairly close together which is convenient. Seems like it would be ok, but like I said I had never seen it put there before. I guess it all depends on the floor plan and manufacturer. Does anyone here have a setup like this? How does it work out for you? Any complaints about having it all the way on the back? My thought is that sometimes it might require a longer white hose depending on where the hookup was on the pad.
Thanks for any feedback.
2007 Thor Wave 26RLS
2004 Chevy 2500HD Gas Hog
DW Michelle, Son Tyler, Daughter Kaitlyn, and one on the way!
ArnieJ-NH
N. Swanzey, NH
Posted: 05/13/08 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
My Jay Feather 25F also has the city water hookup on the back of the trailer next to the external shower station. I haven't used it yet, but I don't see that there will be any problems. I have 50' of hose if needed.
Arnie
Arnie & Mary
2004 4WD Dodge Durango w/5.7L Hemi/3.55/Tow Package
Reese WDH w/Dual Cam, Prodigy Brake Controller
2008 Jayco JayFeather 25F LGT
USAF (Ret) 1962-84 B-52D/G & FB-111A
Ham - N1BAC
My Traveling Web Page
mwebber78
New England
Posted: 05/13/08 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is on the rear also, it is to minimize the plumbing used since my bathroom is in the rear and the kitchen just aft of the axles. Also, the outside shower is on the same side.
No issues I know of.
Michael
2 DD's and my DW
6 Acre's of Maine
2009 Crossroads Cruiser CF31SB
2008 Chevy 2500HD Ext. Cab LT 4X4
Camping Pictures
SuperDutyMan
Western PA.
Posted: 05/13/08 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is at the back,my only problem is the FW tank holds 45 gal.s at 7+ lbs.a gallon,and when it's that far back on a 30' TT,it really changes the tongue weight and changes the way it pulls,compared with when it's empty.
2008 Keystone Cougar XLite 29RLS
2006 Super Duty V10 6 Speed 4.10S Tow Command Tow Pkg. 4X4
jtwisconsin
Menomonie, WI
Posted: 05/13/08 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is at the back as well, right next to the outside shower.
John, the lovely wife, plus the 3 kids.
2007 Jayco Jay Flight 31BHS - Parked at the Seasonal Site
Previous setups...
2002 Ford Explorer V6 pulling 2000 Trail-Lite Bantam B19
1997 Chevy Blazer pulling small Coleman popup
Hornet28BHDS
Parker, PA
Posted: 05/13/08 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think that would be a huge issue.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
ProductLeadership
SoCal
Posted: 05/14/08 08:14am Link  |  Quote  |  Print  |  Notify Moderator
He's just talking about city water hookup - not the actual tank fill - so does not indicate fresh water tank location. (Fresh tanks near the rear of the trailer have the most noticeable tongue weight impact, as they can actually reduce the tongue weight and change towing characteristics substantially.)
And you're right - it will work fine and its just got to do with the layout of the floorplan, and where plumbing could be buried with the minimal effect on interior storage.
Drippin
Dripping Springs, TX
Posted: 05/14/08 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Sounds better than mine which is right above my shore power line. I was hoping to install a removable power cord but not with the posibility of the water inlet dripping right on it.
A man, his wife, a son and Cody the Goldendoodle.
2008 Laredo 284BHS, 2001 Chevy Sliverado 2500HD 4X4 4.10, Equal-i-zer, Primus
