RV.Net Open Roads Forum: Tech Issues: kitchen sink replacement
 > kitchen sink replacement
ILLINOISAMF
SWANSEA IL USA
Posted: 05/13/08 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone replaced the double sink in their camper with a single bowl
type. The sinks are mostly so small you can't wash a larger pot or pan. And do you have a source for them?
Fisherman
Angus, Ontario, Canada
Posted: 05/13/08 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
I've thought about it, usually when the pots too big for the sink, but when I'm done, that thought just goes down the proberbial drain with the suds. Take measurements and beat me to Home Depot/Lowes or any other home plumbing shop, and let us both know. Don't forget you have to change the drain to one outlet too.
Burro
U.S.A.
Posted: 05/13/08 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
I have the "European" sink: one great BIG sink and one little tiny one. I hate it and am working on DH to find a replacement.
Les Curren
U.S.A.
Posted: 05/13/08 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
If you are going to a bigger sink, one thing you better take into consideration is your water supply. Especially if you do any dry camping.
Cox89XJ
Tennessee
Posted: 05/13/08 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
The plastic double bowl one big the other small, one in my camper cracked at the drains. I replaced with it with a stainless steel double bowl one with equal size bowls from Home Depot. (Dayton was the mfg.). They had to order it and it was there in 3 days. Cost about $115. Meesure it good before you go to looking. I had to cut mine out about 3/4 inch wider for it to fit. Fits good.
Mfan
Otsego,Mi
Posted: 05/14/08 06:27am Link  |  Quote  |  Print  |  Notify Moderator
The sinks are small so we don't use as much water. Just be sure to measure well before replacing.
