I have a 2007 Jayco 27BH. I have a stupid question. I have lost the owners manual. I want to open the valves that go to the water heater. I remember closing two, of three of them last winter. There are two lines going into the heater, and they are teed before they enter the heater. Do I open the top, and bottom one, and leave the T valve closed ?
if it's like mine, picture a large "H" with a valve at each bottom and one on the cross member. the 2 bottom ones are the inlet/outlet from hot water tank.
normal use the bottom ones are open and cross menber one closed-for winterizing it's reversed
2004 silverado 2500HD crew cab 4x4 long bed 8.1L gas hog
2006 skyline nomad 3260 platium edition, prodigy, reese dual cam
1 very part time camping son and 3 full time camping, 4 legged fur balls
1 SU (spousal unit) who loves rv'in as much or more than me
You want water flowing into the heater through the bottom line, and water flowing out through the top line. Any valve between the two should be closed except when bypassing. So it sounds like you had it right in the first place.
'05 Cherokee Lite 28A
'05 F250 6.0 PSD, FX4, stock
"You can find some good in everybody; sometimes you have to look real hard, but it's there!"
