gdcskc
Kingfisher, OK
I have a Dometic refrigerator in my fiver. We turn it on a day or two before we're ready to load it up for a trip. It will cool down normally and will stay around 35 degrees for a couple of days. Then it will, all of a sudden, warm up to anywhere from 55 to 70 for a few hours. Then it will cool back down into the 30's for another couple of days. All while it is doing this, the freezer compartment stays around 15.
Has anyone had any experience with this kind of trouble?
CISCO8325
Escondido, Ca.
you may try to use a fan inside it to keep the air circulation.most dont have this and this could be the result of it.
edited 05/14/08 09:23am by CISCO8325 *
wayne_tw
South Dakota/Georgia
Sounds to me like one of two things:
1. Addition of enough non-precooled items to raise the temperature, or
2. Opening door often or long enough to expell the cooled air.
Since the freezer mantains its temperature and the refirgerator recovers from the higher temperatures, I suspect it is operator error and not an issue with the refrigerator itself.
gdcskc
Kingfisher, OK
wayne_tw wrote: Sounds to me like one of two things:
I suspected similar, but tested it out this week. The fridge is empty. I turned it on Sunday night. Opened the door Monday morning 38 degrees. Opened the door Monday evening, 36 degrees. Opened the door Tuesday morning, 37 degrees. Opened the door Tuesday evening 68 degrees. Opened the door Wednesday morning, 35 degrees. Each time I checked the fridge, I checked the freezer and it was consistently 15 - 18. The doors were open for about 5 seconds each time.
JFG
TN
Rv refers are not frost free like home units. They cycle like that to clear ice/frost off the cooling coils every few days. Your owners manual probably covers this.
Fred
Crazy Ray
Monroe,La
FRANK What is a FAX????? Don't you mean a FAN????
RET Army , DW Donna , Summer (Furkid) . Class A, 2000 Gulf Stream, DIRECTV, YAMAHA 2400 GEN , TOW 97 Wrangler. Garmin GPS 2720 . "Living Our Dream". NASCAR FAN (20,18,11,29,31) Love CO & NM
enblethen
Moses Lake, WA USA
Check for a loose connection on the thermister. The thermister is located on the metal fins of the refer. It has two small wires going to the circuit board in the exterior refer access.
It is possible that it is failing, but check for loose connections first.
Bud
Suzuki XL7 pushing Pace Arrow
gdcskc
Kingfisher, OK
enblethen wrote: Check for a loose connection on the thermister. The thermister is located on the metal fins of the refer. It has two small wires going to the circuit board in the exterior refer access.
Thanks for the suggestion, I'll check it out.
CISCO8325
Escondido, Ca.
oops my bad I meant FAN..ahahaha he can fax the air threw ahaha..sorry finger check
shutdown
In The Dog House
I'd say its doing a defrost cycle. How long will it remain at 65? A few hours?
