RV.Net Open Roads Forum: Class A Motorhomes: Washer-Dryer en route
 > Washer-Dryer en route
Rich_in_Florida
Tampa, Florida
Posted: 05/14/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Can I assume that in any class A with a washer-dryer you can run the unit (with propane and/or generator running) while rolling?
I realize there are theoretic concerns about the safety or driving with propane open, etc. but just wondering about whether we can wash and roll at the same time.
Rich
Tampa, Florida
Trailmanor 3124KS 2008
rv2go
Somewhere between Knoxville, TN and the coast.
Posted: 05/14/08 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Just make sure your fresh water tank is full and the gray tank is large enough and empty before you start.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee
www.rv2go.us
I'm here #4335
Picasa Photos
klm
SIOUX FALLS, SD
Posted: 05/14/08 08:29am Link  |  Quote  |  Print  |  Notify Moderator
I haven't done it, yet!! We are taking summer trip to Alaska, so doing laundry along the way might leave us with more time to enjoy the sights and not be stuck doing "chores". Generator and enough fresh water in the tank, and an empty gray tank should do it. If you use the "express" cycle it uses 10 gal of h2o. Of course, mine shakes the whole coach on the spin cycle- so hold on to that steering wheel!!! Hopefully, someone with experience will answer you. Kathy
'02 KOUNTRY STAR DP
'04 PT CRUISER INFERNO RED
LUCKY THE TRAVELIN'BLACK CAT
LandYachtLadySandra
Angleton, TX
Posted: 05/14/08 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Many, if not most, motorhome washer dryers dry with AC electricity, not propane.
However, there may be a concern regarding movement underway and its effect of the washer drum.
LandYachtLadySandra
2004 Fleetwood Revolution 40C
2006 Dodge Dakota Club Cab 4X4 carrying two EGO electric scooters
KE5LUU
Chipper, the 7 year old 7 lb chihuahua/? mix, a rescue dog
Sassy, the 1 year old 4 lb. chihuahua/pomeranian, his "sister"
Ron & Shirley
Lake of the Ozarks Missouri / Donna Texas Winter
Posted: 05/14/08 08:39am Link  |  Quote  |  Print  |  Notify Moderator
I was advised not to run it while in motion. The reason was that if you hit a bump it could cause damage to the drum to be shifted suddenly.
So I don't.
Shirley
Ron & Shirley
2005 Itasca 37B Suncruiser W24 Workhorse Chassis
To Discover New Oceans We Must Lose Sight Of The Shore
crickeydog
Marietta, Ga.
Posted: 05/14/08 08:40am Link  |  Quote  |  Print  |  Notify Moderator
IMHO: Because of the vehicle movement's possible adverse effect on the washer agitator or drum while the washer is operating, I personally wouldn't wash and roll. A washer full of water is alot of weight to start with and combine that weight with the effect's of vehicle movement and you have alot of force working there inside the washer drum.
Happy camping!!! See ya'll down the road!!!
AIR FORCE RETIRED "EITHER LEAD,FOLLLOW,OR GET OUT OF MY WAY"!
2006 GMC 3500 SLT CC DRW 4X4 D/A LBZ,PREDATOR & FS2500 OIL FILTER
2004 HR PRESIDENTIAL 30 SCD 5'ER.
CHEROKEE & CHEYENNE, MINI DOXIE'S
LOADED LIKE A FREIGHT TRAIN, FLYIN LIKE A JET PLANE!!
hr
Midwest
Posted: 05/14/08 08:42am Link  |  Quote  |  Print  |  Notify Moderator
I know a lot of people that do it ,Just make sure your gray tank is empty when you start and you will need to run your generator for power.It uses vary little water so the weight is not that great.
HR
Ames
South Central Florida
Posted: 05/14/08 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Total weight does not change from the fresh water to gray water tank hr (sorry I could not resist).
Some washer dryers run directly to the dump valve area and by pass the holding tank and the owners manual says the gray water valve must be open to use the washer. You can leave the gray valve open and the cap on and get by but shut it and have the sewer hose ready to catch the gray water when you hook up. A cap with the hose bib makes it easier.
The washer requires a 110 power source (generator) to work. Shutting off the propane while driving is overkill IMO. LP systems are designed to operate while in motion and some people need to use their propane generator. We propane and fuel are in approved containers and delivery systems.
Richard and Babs and a Bob Tail Cat
97 Beaver Patriot 40 Kitchen Slide
330 HP Member FMCA, BAC, Good Sam, CAT RV Club
Toad 04 Durango HEMI
hohenwald48
Hohenwald, TN
Posted: 05/14/08 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
We do it all the time. Since the washer only holds about 3 gallons of water I can't imagine the 24 pounds of water being any kind of problem. The book says it takes 15 gallons to do a regular load so make sure you have enough holding tank for the number of loads you plan to wash.
2001 Monaco Knight
2004 Dutchmen Dorado
1999 Jeep Wrangler
100% Solar Powered Home
IGNORE YOUR RIGHTS AND THEY'LL GO AWAY
John M
Grayslake, Illlinois
Posted: 05/14/08 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
In some floorplans, the washer/dryer is behind a slide when the slide is in, thus making it inaccessible. One of the things we like about our floorplan is that we could use the washer/dryer while under way, but we never have.
John and Susan
2005 Itasca Meridian
Jeep Wrangler Toad
