RV.Net Open Roads Forum: Class A Motorhomes: stale gas, interesting article if interested
 > stale gas, interesting article if interested
tonkatoys
maine
Posted: 05/14/08 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
http://www.straightdope.com/columns/060825.html
D.R.Bain
Michigan
Posted: 05/14/08 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Never had a problem with the gas. I use gas in the lawnmower and snowblower, so those cans are filled as needed year around. In the MH all I do is fill it up just before it goes into storage for 5 months. I haven't had a single problem with it or performance in any of my MHs.
Dan, 2007 Damon Daybreak 3270
Wherever I happen to park
Posted: 05/14/08 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
I have had gas go bad.. I do use Sta-bil (now) and have not had a problem since
One interesting fact is that in many areas there are "Summer" and "Winter" fuels
Gas bought in august may not work well in a small engine come January
But might come next July.
wny_pat
Western NYS
Posted: 05/14/08 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
I'm a old fart who has never had a problem with stale gas, you know, the kind in a engine! And I was in a out of gas refineries for years. Can tell you other stuff it does to you though! But you don't want to know about that stuff!
pkunk
Questa, NM
Posted: 05/14/08 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
I have an old Ford PU that runs on propane, mostly. It gets used more in the winter, plowing snow. I keep the gasoline tank full in case I run out of propane (dual fuel) and that gas is close to 3 years old now. About once a month i run on gasoline for a mile or so to keep the carb wet. I can't understand 'stale gas'.
1989 Allegro, 30 ft., 454 CI 4 BBL, 3 spd.auto, 125gal.gas tank,85g.water & 85 grey &75 black holding tanks. 3-12v Optima 31m coach batteries
tom_kat
way upstate new york/lake george area
Posted: 05/14/08 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
i have a couple of vehicals that have gas a couple of years old they still start and run you can smell the old gas when there running the old gas does lack the power of new,i add some fresh gas couple of gallons to the tanks a couple of times a year to freshen the old stuff up,if or when they go back on the road one fresh tank of gas and they will run as befor thats just my opinion and what works for me i wouldnt run old 2 yr old gas in my mowers or garden tractor or generator thou or leave gas in them over the winter it gums them up to much.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
trpwire
belleview, florida
Posted: 05/23/08 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
Run some "Sea-Foam" gas additive thru your tank from time to time to eat the varnish out of your system.
garry1p
Broken Arrow, OK, USA
Posted: 05/23/08 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Old gas doesn't smell like fresh gas but will burn.
2 year old gas and I drop to about 6 mpg a loss of 2 mpg. Takes about 2 or 3 fill ups to get back to the 8 mpg range.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
