MGO BLUE
CAPE CORAL FL
WENT TO DARLINGTON LAST WEEK COULD NOT GET ANY CONNECTION...TOOK MY BOX TO RV NEXT DOOR IT WORKED FINE ..CALLED DIRECT THEY SAID I NEED TO RECEIVE ANT AT 72 DEGREES ...ALL I WAS GETTING IS 101 110 AND 119 DEGREES ..GOT BACK TO FLORIDA STOPPED AT FLYING J IT WORKED FINE...HOWEVER AT NO TIME CAN I GET LOCALS IN THE BUS ..EVEN SETTING IN MY DRIVEWAY.. TAKE THE BOX OUT PUT IT IN STICK HOUSE IT WORKS FINE...IF I PUT IT ON LOCAL NBC I GET AN ENCORE MOVIE CHANNEL ABC I GET CHANNEL 200 (INSTRUCTIONS HOW TO USE DIRECT TV) CBS I GET A RELIGIOUS CHANNEL DIRECT SAYS ITS MY DISH...WHICH IS A KVH STATIONARY ANY IDEAS JIM K
Enjoying the Lagniappe
Destin,FL,US
When you type in all caps it is considered yelling. Please do not yell as you are asking for assistance.
Are they telling you that your locals some from a different satellite? If so, is the dish on your coach pointed at the correct satellite?
Sat 110 and 119 are dish network satellites.
I don't know which are the direct tv satellites, but you will have to amke sure that your dish is pointed at the correct satellite.
PapPappy
Wilmington, NC
STOP YELLING!!
Get Direct TV to come and check it out for you...or stop buy their place. It sounds as if it's something in your system, either antenna, or the box, if it doesn't pick-up those other satellites.
Good Luck,
Bill, Claudia, and the Paps
DH Bill / DW Claudia / DD Jenn / DS Chris
The Paps! Sophie, Abby, Brandy, Kahlie and Annie
Purchased April Fools Day, 2008
The Pets
Scrib
San Jose, CA
Jim - I think you need to go into the setup on the receiver (menu/setup/re-do satellite setup - something like that) and select the "Single LNB Round Dish" option.
Good luck!
RJsfishin
Winston Or.
Its not Direct's problem. You've already proved that the receiver is working fine. Their not going to help you.
The problem is in the dish on the RV, which they didn't install nor do they maintain.
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
jim isham
stevensville, michigan
The reason you couldn't get any locals in Darlington was because the Columbia, SC locals are on the 72.5 satellite which you don't have.
You would have needed a second dish in addition to the one you already have.
Michigan's Sunset Coast
M GO BLUE
Southgate, MI
I think someone's trying to steal my name here...
ERIC & BEV
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS
rv2go
Somewhere between Knoxville, TN and the coast.
M GO BLUE wrote: I think someone's trying to steal my name here...
His handle is too near to be right. Looks like the managers of the forums would not allow a name spelled this close. A missed space stroke and you would be someone else.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee
www.rv2go.us
I'm here #4335
Picasa Photos
Big Katuna
Deland, FL
I WAS KIND OF WONDERING WHY YOU WERE TYPING IN ALL CAPS; YOU USUALLY DON'T DO THAT!!!
Once you can accept the universe as matter expanding into nothing that is something, wearing plaids with stripes comes easy.
F350R
Colorado
Since you live in FL and you were visiting Darlington you're not going to get FL local's anyway. Local Ch are broadcast via spotbeam which covers roughly 200 miles. You cannot get the local Ch for Darlington area since you are not authorized for those channels.
04/04 F350 Dually Lariate, 4x4, CC, LB, Auto, Firestone air bags, Bilstein shocks, custom on board air system, cat back 4" Aeroturbine muffler. Two place over head ATV rack, third ATV in the bed.
Four Winds 27BH
