Beerdawg
Massachusetts
Need help......In my water heater I was putting the drain plug back in after the winter. It is one of the plastic type and I guess I overtightened. The head of the plug came off and the thread is still screwed in. I can not grab enough of it with needle nose pliers to turn it to remove it. Any ideas? Thanks
pcm1959
St Augustine, FL
Oh, man! WIsh I had some advise on how to get it out. However, reading your dilema just made me REALLY glad about the $6 I spent at Camping World last week for a brass quick drain water heater drain plug. Good luck. PCM
Drivr
Seabrook, NH
I would very carefully use a hacksaw blade and cut through the plastic in 2 opposite spots then try to pull them out with pliers. heating them up with a hair dryer might make them more flexable as well.
1995 Dodge 2500 extended cab, 8' bed, 5.9L, 4.10's Now!!.
2005 Rockwood 8281ss
http://www.bowleyfamily.com
Caseydon
Simonton, Texas
How about drilling a proper size hole and inserting an Ezeout screw extractor? Apply counterclockwise pressure carefully and steadily, using a wrench or T-handled pin vise.
Casey
ScottG
Bothell Wa.
If you cant find any other way then there's a plumbing tool (really just a big easy-out) that's designed to remove what you describe. Its designed for iron pipe thread but will work for plastic too.
unfortunately it wont be cheap though.
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
DutchmenSport
Indiana
It's plastic. You can easily drill it out. Start with a small drill bit and get bigger and bigger until (a) it falls out, or (b) you can get a screwdriver or pliers on it and screw it out.
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
swebber
Brunswick , MD
drill two holes on opposite sides and then stick a set of needle nose pliers in there to back it out..poor mans ez-out !!
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
gstanton
Oakland, MD and Tierra Verde, FL
swebber has it. At least, that's how I'd do it!
Dusty & Lindsay
Sadie the "Lassie" type collie
Oakland Maryland and Tierra Verde, FL
Our 3rd TT is an '02 26' Nomad Scout
Ford F150
azjeffh
Chandler, AZ
When I snapped my plug head off the thread left was hollow. I took a file with a tapered end a bit smaller than the hole and gently tapped the end beating the file into the plastic (not very much). Then took a pliers and twisted the file which unscrewed the plug.
edited 05/14/08 09:11pm by azjeffh *
Jeff
Wonderful wife Robin, no children, no pets, no money
05 F250 Supercab SB PSD w/Tow Command
05 HR Savoy 29RKS
Dave H M
IL
or heat a big but screw driver up and melt it in there and let things cool and give her a twist.
