hershey
Albuquerque,(fulltime) NM, USA
On my Brake Buddy, I have a light and buzzer wired to it that allows me to know every time the Brake Buddy engages. It has a provision built into it that allows this function. I would believe that other braking systems would have something similar.
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
DrScud
On the Road
427435 wrote: DrScud wrote: Because I installed the system, and I know it works. And because I do the maintenance so I know it is done right.
Are there any electronics in your system? If so, you don't know unless you test them every day.
No electronics. That's the beauty of the M&G system.
Jim & Sim - Fulltiming. - - Follow our adventures at: JimandSim.com
98 Foretravel U320 40', Cummins 450 HP/1450 lb-ft, HD4060 Allison, w/rtrder
2000 Jeep Grand Cherokee Laredo / M & G Braking / Demco Excali-Bar
Current location
ArchHoagland
Clovis, CA, USA
You should be able to manually apply the brakes with the controller.
You will feel the drag when you do it.
What braking system do you have?
2004 Monaco
La Palma 36DBD
Two Slides
2 Potties
Workhorse 22 chassis
8.1 gas engine & Allison transmission
6.9 MPG based on a 6,000 mile trip around the U.S.
US Gear Toad Brakes
Deen
Vancouver, WA
Have someone pull over in front of you going 20 mph slower, then they hit the brakes to try and take the off ramp you're passing!! The howling toad tires let me know they were working fine and the air horns let him know of his stupidity!! Also the smell of burning rubber and cloud are quite a show for people following you!
Then there's the red light in the dash that ONLY comes on when the brake pedal is pressed in the toad.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'97 Grand Cherokee/4 down
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
Bumpyroad
Virginia
I can feel my toad jerk on the motorhome when the brakes are applied. I set the sensitivity down so they only come on under moderately severe braking, I don't want the toad trying to stop the motorhome.
bumpy
Old Bird
Wisconsin
To test mine I have the DW push the break pedal in the coach and I go back to the toad and make sure the toad's break pedal is moving. There is also a toad brake indicator light in the coach, but this is a good double check that it is working. This is for a Roadmaster Brakemaster system, others may be different.
Phil
1983 Blue Bird Wanderlodge FC35
Wisconsin
ShapeShifter
Buffalo, NY
DrScud wrote: ShapeShifter wrote: DrScud wrote: Why do you think they might not be working?
Why would you blindly assume they are working?
I installed my system, I maintain it, I know it works, and I know it was done right. I still test it each day before heading out, however.
You say you know it works, so you must have tested it at least once, right? And you say you maintain it, and that probably involves testing it as well, or at least it should.
So you've pretty much confirmed my point, that braking systems should be tested regularly. Even your purely mechanical air operated system can suffer from stuck pistons, air leaks, or plugged lines. Testing it once at installation time is not enough. But it looks like you know that already, as you've pretty much implied that with what you've written.
So I don't understand why you seem to be questioning the validity of the original question.
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
Will_Robinson
Charlotte, NC
Old Bird wrote: To test mine I have the DW push the break pedal in the coach and I go back to the toad and make sure the toad's break pedal is moving. There is also a toad brake indicator light in the coach, but this is a good double check that it is working. This is for a Roadmaster Brakemaster system, others may be different.
That's exactly what I do. I have the same system.
J & S
Kayla,Gertie & Cheyenne "The Stepford Dogs"
2007 Country Coach Tribute 260 Touring 40' Quad Slide
2007 Honda CR-V EX
Roadmaster Sterling/Brakemaster
Bumpyroad
Virginia
I still don't quite understand the "confusion". my toad brakes are checked every time that the coach brakes are applied with a reasonable amount of force. I can feel the toad jerking backwards on the coach. Isn't that a 'test"?
bumpy
