RV.Net Open Roads Forum: Tech Issues: Charging 5th Wheel Batteries
 > Charging 5th Wheel Batteries
danda
Burney, California
Posted: 05/14/08 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
What is the most efficent way to charge the 5th wheel batteries when camping dry? I have always plugged the trailers shore power cord directly to the generator, and let the trailer converter do the charging. Now, a friend suggested I use my marine battery charger, plug that into the generator and then attach the alligator clips directly to the batteries. I am using an ancient 600W Honda for the generator. Any suggestions out there????
Crazy Ray
Monroe,La
Posted: 05/14/08 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
What size converter ???? I let my 55Amp converter do my btrys. JMO
RET Army , DW Donna , Summer (Furkid) . Class A, 2000 Gulf Stream, DIRECTV, YAMAHA 2400 GEN , TOW 97 Wrangler. Garmin GPS 2720 . "Living Our Dream". NASCAR FAN (20,18,11,29,31) Love CO & NM
portablevcb
Tijeras, NM
Posted: 05/14/08 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Same thing. I use the converter installed in my trailer.
On my old MH the converter was only 6A. So, I'd take my 3 step, 25A battery charger with me, plug it into the genset and clip to the batteries. Charged much faster.
charlie
2006 Toyota Tundra Crew Cab
2003 Skyline Nomad 24ft Fiver
Me and Wife
Maggie the Old English Sheepdog
smkettner
Southern CA
Posted: 05/14/08 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
You will need to post the make and model of the converter and the marine charger to know what is better. 600 watts will only power about 25 to 40 amps of charging.
donn0128
Pronounced Ore-gun
Posted: 05/15/08 08:14am Link  |  Quote  |  Print  |  Notify Moderator
I think you are forgetting that many converters do not have the capabilities to put that much charge load on a battery. Besides that the 600 watt (rated) Honda is only good for about 450 running watts or less than 4 amps into the converter. I would try the battery charger directly from the generator to the batteries and see how fast it will recharge the batteries. But you may want to double check the input amps requirement of the charger to be sure that your Honda will supply it with sufficient amps to run properly.
Donn
Dave H M
IL
Posted: 05/15/08 09:07am Link  |  Quote  |  Print  |  Notify Moderator
give donno's comments some thought. That converter will not divert it's full amperage to battery charging. I don't know the answer but always got better results on the old camper with hooking a battery charger to the batts.
I don't know what a msarine charger is, I used to charge my boat batt with the same charger i have now for all purpose.
tvman44
Southwest Louisiana
Posted: 05/15/08 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Depends on your converter.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Ron44
Jarrettsville, MD.
Posted: 05/17/08 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have been through this scenario already.
Best 2 options in my opinion are...
1)Buy a small portable battery charger that you can hook to your batteries when your generator is running.
2)replace your single stage converter with a 3 stage converter/charger
I opted to upgrade my converter/charger to a 3 stage converter/charge by Power Dynamics(PD9260) with Charge wizard.
05 Chevy Silverado 2500HD Duramax EC LB
06 FR Sandpiper 285RG
PD9260 Conv/Charger
16" Alum. wheels
BFG Commercial LT225/75-16E
Trail-Air Equa-Flex
Reese 15K hitch
Prodigy Brake controller
Honda EU3000i geny
Bilstein shocks
Firestone airbags
Lynn Rupper
Full-timing USA 13 Years
Posted: 05/17/08 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
I run my converter charger with the on-board generator and plug a portable Marine 10 amp battery charger into the 115 V outside plug and aligator clip it to the batteries at the same time. However, I've heard that this won't work with some converters.
2003 Dodge Ram 2500 CTD, 6spd manual, Banks Exhaust Brake
1995 HitchHiker II, 30 RKSBBG, Onan Generator
DRILL HERE
DRILL NOW
PAY LESS
sirdrakejr
Las Vegas, Nevada
Posted: 05/18/08 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from 5th wheels to tech issues.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
