jameswb1
Danville alabama
Do you ever have to add battery acid when cells are low or just keep adding distilled water?Thanks everyone for the helpful information! I will add distilled water only!
edited 05/14/08 11:27pm by jameswb1 *
NHguy
NH
To top off battery you use distilled water, and only fill it enough to cover the plates. If you fill so high the tubes bottoms are wet that's not OK.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, XM Cradle, Battery Disconnect
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
hershey
Albuquerque,(fulltime) NM, USA
Its generally agreed that you never add acid to a wet battery. Just distilled water.
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
teb1272
Memphis
The sulfuric acid is non-volatile, and only water is lost. Only add water. Fill it up to about one eighth inch below the bottoms of the inlet tubes, although I don't really think you hurt anything if the water comes up to touch the tubes. You are more likely to splash acid out if you overfill.
DakotaD
Kodak, Tennessee
Never, never, ever add acid to water. Never. It will cause an explosive reaction. Distilled Water to acid always. If the battery is so
weak as to not hold a charge it's beyond anything short of replacement. Plate sulfication is probably the most commom problem caused by charging constantly without much discharge. Causes the plates to short together which becomes a constant drain on the battery internally. Time is the second battery killer.
Good luck.
...by His grace...
smkettner
Southern CA
Add distilled water only.
beisner
Cincinnati
I found out that the fastest way to add distilled water to my batteries was to use a turkey baster.
Wherever I happen to park
Well... There is some questionable stuff above.. But everyone agrees on the fact
Distilled water.. ONLY distilled water
Kenneth
Washington, the state
Acid is only added when acid is lost, by tipping the battery over, for example.
YC 1
Yuba City Calif.
Always water.
I use this type of device. Battery fill device
