djtkach
Manitoba, Canada
Finally picked up the new TT - Spree 290BHS - and made the journey home from the dealer today. While en route, I kept hearing a jingling noise that sounded like the chains dragging on the pavement. I stopped several times to check and nothing is dragging anywhere. The noise stops when I stop, and starts at around 5 MPH. It isn't coming from the chains rattling as the pitch of the chains is slightly different (tried rattling them myself). Any thoughts?
robbie69
wauconda, il usa
hitch/sway setup may be helpful to know. take it everything was working ok.
does it continue after 5 mph or does it stop? does it happen all the time or during acceleration, stopping, turning?? could try putting a few twists in the chains b4 hooking them up(just a few-not enough to make em stiff)
more info is needed on equipment. grunts, groans, grinds are fairly common and usually a lube problem but a 'jingle' is a new one
2004 silverado 2500HD crew cab 4x4 long bed 8.1L gas hog
2006 skyline nomad 3260 platium edition, prodigy, reese dual cam
1 very part time camping son and 3 full time camping, 4 legged fur balls
1 SU (spousal unit) who loves rv'in as much or more than me
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Might be the new leaf springs squeeking! Tiny little noises might be compared to "jingling"!
fla-gypsy
North Florida
It may be the wind blowing the chains against some other metal trailer part rather than dragging.
05 Super Duty XLT CC 5.4/3.73 5 sp auto Torqshift
06 Keystone Hornet 29 RLS/(The"Cracker Cabana")
Reese HP Dual Cam
Camping Photos
Northeast Florida Camping Club
St Andrews SP cult member
KC8WX
OH IO
Ours does this. There are some Metal Product ID/Ratings Tags (like dog tags), one on each chain (the Safety Chains I am talking about), that flip around and play wind chimes on ours the whole time we are moving. I thought we were dragging chains too, but not so.
edited 05/15/08 04:20pm by KC8WX *
2006 Durango SLT 4.7L, 545RFE, 4.10 Motive Gears with TracLoc 2WD AIRAID Cold Air Intake, PML Deep Tranny Pan, KYB Shocks
2007 Wildwood LE 27RB
Equalizer Hitch
Prodigy Brake Controller
Terryallan
NC
KC8WX wrote: Ours does this. There are some Metal Product ID/Ratings Tags, one on each chain, (like dog tags) that flip around and play wind chimes on ours the whole time we are moving. I thought we were dragging chains too, but not so.
Mine did this as well.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
H4Adventures
Minot, North Dakota
Does it have electric brakes? I am assuming it does, if nothing else, I would just make sure there is nothing loose there that might rub the drum, I have seen loose calipers in cars make a jingling sound and it might do the same if that were the problem. Does the sound stop when you apply the brakes at speed?
2007 Zinger ZT30BH
2008 GMC Sierra 2500HD CC, 6.0/4.10
2004 Chevy Trailblazer
2003 Tracker Avalanche, 150EFI Merc.
Campfire Time
Wisconsin
H4Adventures wrote: Does it have electric brakes? I am assuming it does, if nothing else, I would just make sure there is nothing loose there that might rub the drum, I have seen loose calipers in cars make a jingling sound and it might do the same if that were the problem. Does the sound stop when you apply the brakes at speed?
Excellent suggestion. When new, ours made a noise as described by the OP. I could never find it. It turned out to be the adjuster screw had fallen out and was bouncing around inside the drum. I was fortunate, no damage to the brakes, and more important, no panic stop issues that might have caused an accident.
Chuck D.
'03 Jayco Kiwi 17a, '03 Chevy Trailblazer EXT, Garmin Nuvi 200 GPS
Photography is my obsession: http://coldwater.smugmug.com/
“Adventure is just bad planning.” - Roald Amundsen
djtkach
Manitoba, Canada
Hitch is Reese dual cam 1200# trunnion style. The noise is constant from about 5mph and persists at highway speed.
ImRebel
I think the problem is your radio is not turned up loud enough.
Kent & Kim
2008 Springdale 267BHLGL
2003 Ford F250 CC LB 4x2 V10
