WhitehouseLV
Formerly Las Vegas, Now Big Sky State - Montana
last year a gust of wind destroyed ours. come to find out the bolts weren't screwed into anything and they ripped out easily causing the entire awning to get flung over our fiver. We had it replaced under warranty and the dealer fixed the problem, but I'm still a little paranoid. So, how do you secure your awning or do you?
Traveling Whitehouse
2006 Keystone Raptor 3612DS
2004 Chevrolet Silverado 3500 CC LB DRW Duramax LLY 4x4
Reese 20K Hitch
Prodigy Brake Control
pair of Honda Ranchers and an old 88 Honda XR
fordsooperdootydieselsmoker
OrangeCountyCalifornia
We've always followed the rule to roll up the awning when we're not there! At night we can hear if the wind starts gusting, and many a cold night I've gone out and rolled it up in a hurry. Same with a heavy wind. I think it's OK to have it screwed into something like the aluminum siding that will give way without damaging anything, rather be screwed into wood stringers what may crack and split causing even more damages to the RV.
Cox89XJ
Tennessee
We use the screw in anchors with straps on each end, similar to what you would anchor a dog leash on. Also de-flappers. When it gets stormy, we roll it up. I've gotten up during the night a many of time and rolled it up.
PackerBacker
Montreal, Quebec,Canada
Cox89XJ wrote: We use the screw in anchors with straps on each end, similar to what you would anchor a dog leash on. Also de-flappers. When it gets stormy, we roll it up. I've gotten up during the night a many of time and rolled it up.
Same here.
Eric
2004 Wildcat 27RL, Honda EU-2000i.
2003 Dodge Ram 2500 Hemi, 3.73, Reese 16K, Prodigy,long box, Line-X,
Good Sam's - FQCC/Camping Quebec
My Photos
kknowlton
Wisconsin Border Country, IL
I think what Cox is referring to is tie-down straps. You can buy them specifically for awnings. They work well, but if it's stormy and VERY windy, I'd pull in the awning.
swebber
Brunswick , MD
I use the de-flappers and also put a bungee strap over the awning tube at each end and then hook a ratchet strap(color coordinated of course )to the bungee and the other end to stabilizer jack. I tighten it down to just put some tension on the awning arms.
In heavy winds I roll the awning up.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
Charlie Q
Brusly, Louisiana
I use de-flappers and the screw in anchors and bright orange ratchet straps to the anchors. I've had to put it up a couple of times because I got nervous but I know people that leaves it out no matter what.
'03 Chevy CC/SB,D/A,4X4, Airlift Bags, Bilsteins, Reese slider, Hypertech programmer.
'06 Mobile Scout 31 BWFS
Yamaha 3000ISEB
mike54
Woodstock,IL
at our seasonal site I have hooks screwed to the deck when we are on the road I use screw in anchors. awning Deflappers help to.
Mike
2008 Croosroads Zinger 25RK
Wi. rallys attended IL. Rallys
2002 Silverado crew cab 2500HD 6.0 4:10 gears
RVN4US
IOWA
Put in up when I am gone, and when I go to bed if the weather even looks bad, have never had a problem and I've been able to sleep all night.
RVN4US
IOWA
Opie431
Bellevue, MI
We have the anchors plus we always tie it to the picnic table or nearby trees.
If there is going to be a real bad wind we take it in but once we got home to howling winds and it was still fine.
This would not work for people who camp on cement and without nearby trees.
