bubbabean
virginia
Hello,
I am trying to find the smallest window A/C unit made. I have a very small window opening 15"W x 12"H...anyone have any ideas?
Thanks
rushin roulette
Beautiful *cough* Bakersfield
I presume you are wanting to mount it in you RV. The smallest units I've installed were 5000 BTU window units that just may come under that sizing. You won't notice much cooling from those in a B.
This Sear model is around 11 X 18 for example
here
You may want to look into a rooftop or portable unit, but they are certainly more expensive.
Busted a U-joint at the crossroads of life.
ARcruiser
Benton, AR USA
Hmm... width may be a problem.
I'm probably gonna use a 6,000 btu Frigidaire....
they list 2 models at 5,000 btu (their smallest) and show the width to be 15 1/2" and height at 11 2/5".
2 Big Cruisers, The Little Man, and Bailey / ARcruiser's Class B's (the first 8)
Rig #8 Under Construction! / Here's the Project Thread - I'm actually working on it again!
Bob N.
Elkin, NC 28621
Hi,
We had a home converted camper on a short wheelbase Ford van. We had a 5000 BTU a/c mounted in the tall top, and it was inadequate in hot weather. Our unit was pretty well insulated, and smaller than the average B. I would suggest you not go any smaller than 7500 BTU if you are going to be where the weather is hotter that 75 deg F.
Bob N
2002LTV Freedom 2a
VernM
Marion County, AR
Have you explored this site?
https://www.compactappliance.com/jump.jsp?itemID=0&itemType=HOME_PAGE
VernM
GMC Conversion van/Wells Cargo MiniWagon trailer
Sent via HughesNet/SatMex5 Internet Portal
Rodger
Tucson, AZ.
You can view this topic here. http://www.trailerlife.com/cforum/index.cfm/fuseaction/thread/tid/21416359.cfm
Please do not double post.
Forum Rules: "You are not allowed to post the same message in multiple forums without permission from one of the Open Roads Forum moderators."
Rodger (Moderator)
