RV.Net Open Roads Forum: Truck Campers: Smallest Window A/C Unit
 > Smallest Window A/C Unit
bubbabean
virginia
Posted: 05/15/08 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Hello,
I am trying to find the smallest window A/C unit made. I have a very small window opening 15"W x 12"H...anyone have any ideas? I do not want to cut any holes in my TC or put in a roof unit...I will only need it 4 or 5 times a year. Portable A/C unit is an option I have been considering, but I would rather have a small window unit.
Thanks
galexander
Omaha,Nebraska
Posted: 05/15/08 11:59am Link  |  Quote  |  Print  |  Notify Moderator
I would suggest going to Walmart or some other discount store and look at some of their units. A 5,000 BTU unit is the smallest I've seen and it was pretty small but I have no idea what the dimensions would be. Good Luck in your endeavors.
2003 Chevy Silveraldo 2500HD 4x4 SB Ext.Cab 6.0L
2008 Palomino Bronco 1251SB
Structural
Quad Cities, IL
Posted: 05/15/08 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Find a manufacturer & visit their website. They often have specs for individual models. See GE's website - they have many models with dimensions given.
Or - see what's available at your local Wal-mart, open the box & measure it.
My Northstar TC800 has a small ~5000btu GE air conditioner.
Kevin
2005 Northstar TC800
2003 Dodge Ram 1500 4wd Quad Cab with Timbrens & Rancho 9000XL
rv2go
Somewhere between Knoxville, TN and the coast.
Posted: 05/15/08 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
If you can find an extra half inch in width this one will work.
The Gibson GAX052P7A 5000 BTU Room Air Conditioner Specifications:5,000 BTU
5.1 Amps(Cool)
515 Watts(Cool)
6' power cord
Dimensions: 13" L x 15.5" W x 11.5" H
1-year manufacturer's warranty
Limited 2nd - 5th Year Warranty: Sealed Refrigeration System
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee
www.rv2go.us
I'm here #4335
Picasa Photos
rwm2_2000
Reynolds Ga
Posted: 05/15/08 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
I got a 6500btu ac from Walmart in mine...17 1/4 by 11 1/2. A 5000 btu might be smaller but if U had to U might take an inch off each side.
PJ Colahan
Antioch, CA
Posted: 05/15/08 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
There is a marine type unit built by Marine Air (M/N CO-7000) that is designed as a portable unit. It fits through the hatch on a boat but would also fit through one of the roof vents as well. You put it in place when you need it and store it out of the way when not required and you don't have to subject your TC window to the strain of supporting a unit
I saw one at West Marine. Looked pretty good. I think there my be one for sale on Ebay or Craigslist but can't remember.
wcjeep
Tacoma, Wa
Posted: 05/15/08 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Latest Cabela's ad had a small portable for $79.
http://www.cabelas.com/cabelas/en/templates/product/standard-item.jsp?_DARGS=/cabelas/en/common/catalog/item-link.jsp_A&_DAV=MainCatcat20075-cat280029&id=0053085518260a&navCount=1&podId=0053085&parentId=cat280029&masterpathid=&navAction=push&catalogCode=IJ&rid=&parentType=index&indexId=cat280029&hasJS=true
hamidlmt
Gresham, Oregon
Posted: 05/15/08 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like a swamp cooler that you fill with ice. Not a real A/C. But, not do a pinch if you're sitting in front of it!
ScottG
Bothell Wa.
Posted: 05/15/08 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
There are a number of small suitcase style AC units that just run a hose out the window to work.
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
ARcruiser
Benton, AR USA
Posted: 06/07/08 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Got any links for those - or just one example?
I'd be very interested.
2 Big Cruisers, The Little Man, and Bailey / ARcruiser's Class B's (the first 8)
Rig #8 Under Construction! / Here's the Project Thread - I'm actually working on it again!
