RV.Net Open Roads Forum: Class A Motorhomes: Replace Window
 > Replace Window
surfride
San Diego, CA, US
Posted: 05/15/08 11:55am Link  |  Quote  |  Print  |  Notify Moderator
I need to replace a side window on my 05 Southwind. I have the window, came custom from Atwood. Before I start the project, I was wondering if anyone can share their experience replacing a window on a late model Fleetwood. I am uncertain what how they sealed the window in the frame. It does not appear to be the traditional puddy tape used in trailers.
Thanks!
~surfride
snookmjt
On the road
Posted: 05/15/08 11:57am Link  |  Quote  |  Print  |  Notify Moderator
I had to replace a side window on my Mandalay. After careful consideration, I contacted a glass-replacement company from the yellow pages. Two nice guys came out and did it. First time for them, they did a great job. No leaks. Took the old window away too.
Tim and Mary Jane
Mandalay 40B
Bearnkat
Fort Worth, Texas
Posted: 05/15/08 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
I too had a window replaced in our TT. I ended up letting the dealer take care of the installation.
Chuck & Terry
2005 Pilgrim 281RB-S
2006 Ford F250 Lariat CC 4x2 PSD
My Lap-Band Journey!
DFW/Central Texas Rally - Fall 2008
Chuck and Terry's Pilgrim Adventures
North Texas Camping Association
Lone Star Dutch Oven Society
Joy
Henderson KY 42420
Posted: 05/15/08 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
I watched the guys replace one of ours - one guy removed the screws from the inside frame and pulledit off, then pushed out the remaining frame w/glass to the outside guy. After cleaning off the opening, they put on a silicone caulking sealer all around the opening, placed the outside frame/glass in the opening, reattached the inside frame and were done. Simple but does need two people - can be pretty heavy depending upon the size of the window.
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Katie-Mini Aussie
Sam-Calico Fat Cat
Maggie-Chihuahua
2003 38'Phaeton DP
2006 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
itsalleasy
Posted: 05/15/08 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Same method of removal as Joy posted. If it won't come loose it will help to use a plastic putty knife to get between the body and window frame. To reseal I use butyl tape.
RLS7201
Gladstone, MO
Posted: 05/15/08 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
Atwood uses a rubber seal on the window frame, not putty tape. Use a putty knife to break the seal loose from the fiberglass. You may want to apply a small amount of your favorite sealant to the rubber gasket when reinstalling the frame.
Richard & MichĂȘle Shields
Northland Good Sams
1995 Bounder
32H F53
Banks, TruTrac, Vena
2003 PT Cruiser Pusher
FMCA 395470
Web Page
Retired and traveling on your hard earned SS $$. Thanks for your support.
surfride
San Diego, CA, US
Posted: 05/15/08 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
I wonder if Atwood would talk to me... The window did not ship with a gasket. Actually I am a little miffed their window failed in less than three years -and- it was 600 for just the window. I digress. Thanks for the advice, not sure what to do...
oldrvdoc
Anaheim, CA.
Posted: 05/15/08 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Atwood should talk to you, but if not go to a auto window glass company and let them recommend a sealer. Joy, was right it does take two people to get the job done right. A silicone sealer would probably be better than butyl tape.
itsalleasy
Posted: 05/15/08 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Read this.
Bobsyouruncle's experience with silicone and butyl is the same as mine. The silicone is going to pull free from the window or the body and leak, the butyl tape won't. Silicone will flex but it won't flex and adhere long term.
Trailering Texans
Huntsville, Texas
Posted: 05/15/08 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
Since you have already invested $600 I would go to a glass company and let them do a professional job of it.
 > Replace Window
