RV.Net Open Roads Forum: Travel Trailers: Help for a Concerned Newbie!
 > Help for a Concerned Newbie!
owen0704
Michigan
Posted: 05/15/08 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Hello all,
In getting my TT ready for our first excursion next week something happened that concerned me. It appears that at some point (seems to be related to either the water heater or the pump starting up and/or shutting down) I'm get a little water coming from under the bunk house. It happened twice yesterday, but I couldn't pinpoint when and why.
Could I be doing things in the wrong order? I am very concerned about this and am wondering if I need to pull the bunk or water heater to make sure there are no leaks and/or water damage. I filled my fresh water tank to sanitize the tanks, drained, then hooked up to the city inlet with a regulator to flush that out as well.
I'm new to this so if I am omitting any relevant info please ask and I will add anything needed.
2003 Coachmen Spirit 248
Rich
troll3193
SouthWest, MI USA
Posted: 05/15/08 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
you might have low point drains for the water system there that are open??
Do you do your own winterization/de-winterization or have someone else do it??
on one TT I had they looked like cap plugs screwed on the ends of two small pieces of pipe. On my current TT, they are two small valves you reach from the inside they have small metal rings on them and you pull them up to open, push them down to close...
my thought..
Bryan
2006 RAM 3500 MegaCab w/Cummins Turbo Diesel
Mopar Exhaust Brake
2004 Dutchemen 31BK
owen0704
Michigan
Posted: 05/15/08 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
Bryan,
I just bought this over the winter so it was already winterized. I probably should've specified that each time I had water in front of the bunkhouse it was maybe only about 8-12 oz.
If this was an open drain like you suspect, would it be accessible from only the outside?
Thanks.
trnfla
Tampa
Posted: 05/15/08 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
I would check all of the water connection in the area of the leak. Also, do not hook up the city water. fill the water tank and turn on the pump while looking for the leak. Listen carefully for the pump to cycle on and off. If it does that means you have a small leak somewhere in the pressure pipes. If it does not cycle on and off. Turn off pump and hook up the city water. Watch and see if water is leaking. If so you need to figure out whats between the city connection and the pipes. If no water is leaking then start checking your drains for the leak.
Have a great time camping,
Terry
Please visit my Photos and Blog NiceCamps.com
New (2 me) 2004 Winnie 31C
2006 Expedition EB, replaced by scooter and 2008 Mazda 3
Had 2007 Zeppelin EZ190, Prodigy, Equalizer
troll3193
SouthWest, MI USA
Posted: 05/15/08 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
owen0704 wrote:
Bryan,
Thanks.
is the water inside the trailer our outside... on my old trailer, the low point drains looked like plastic compression fitting caps that screwed on the ends of little sections of pipe that stuck ou tthe bottom of the TT..
my current TT has a plastic tray cut into the floor under one of the vanities... in that tray there are two little valves that you open from the inside, but the water drains out little pipes that stick out the bottom of the TT...
you could have a low point that is leaking, or a joint that is leaking might have to follow the pipes and see where they go.
Bryan
FANDUDE
Bethlehem, Pa.
Posted: 05/15/08 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with TRNFLA. We had an issue with our plumbing last year during a re-build. The pipes were solid using the on board pump, but would leak using the city water hook up due to the additional water pressure. The city water had a bit more pressure even with a regulator. We ended up going over every joint / connection with a wad of toilet paper. fastest way to find a leak is with T.P.
DOG IS OUR CO-PILOT
1990 Dodge D-150, 318 cid, 727 Load Flight, 1970 FAN Style Liner 22'
Draw Tite Class 4 W.D. - Kelsey Hayes Elect/Hyraulic Controller
Plain, simple and dependable!
