RV.Net Open Roads Forum: Toy Haulers: Working under toy hauler, getting through plastic
Search only in Toy Haulers
 > Working under toy hauler, getting through plastic
Billgear
Concord
Posted: 05/15/08 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
I have picked up a used Wanderer toy hauler. I want to put in additional tie down points and E track. The underside of the toy hauler is enclosed with plastic with insulation under that. Do I just cut a slit in the stuff and tape it up to get under it? I started to pull the staples from under the siding to see if I could completely drop the plastic down, but the stuff is wrapped up under the exterior walls. Is there some kind of tape that works well with this stuff (duct tape???) Any help would be appreciated.
Thanks,
Bill
Hookem2004
Milpitas, CA
Posted: 05/15/08 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
Just get some long bolts and poke it through the insulation and plastic and through a backing board. Just make sure your backing board is long enough to overlap the stringers and you can see where those are by the staples.
2006 302 Skyline Rampage TH
2006 3500 Duramax CC/Dually
2004 2500 Suburban
2000 1950 Lund Tyee 200HP Yamaha HPDI
nny12972
NY
Posted: 05/16/08 05:50am Link  |  Quote  |  Print  |  Notify Moderator
And forget about duct tape!
J
Chickie
Slatington,Pa USA
Posted: 05/16/08 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Billgear we had our KZ in for repairs and dealer cut the underside covering like you said. Then when finished he used a special tape to cover the slit. He also told me they have this special tape for sale. So far there is 10,000 miles on the tape and it hasn't come loose yet. I sure wouldn't let it open as you can get water or critters in there IMHO.
Good Sam Life member
GWRRA member
NRA Life member
2002 F350 Lariat SC 4x4 PSD 6 speed,
1993 Goldwing Aspencade/2006 CSC trike conversion
2008 KZ Sportsmen Sportster 35'
1997 Honda PC800, for mileage
MoombaHauler
Reno, NV
Posted: 05/16/08 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
You could use Eternabond. That stuff sticks like mad!!
2000 Ford Expedition Eddie Bauer 4X4
2005 Ford Expedition Limited 4X4
For the Desert:
2008 Thor Tahoe Lighthauler 26FS
1998 XR400R
2004 TRX250EX
2001 KLX300R
2001 XR100R
For the Lake:
2005 Moomba Outback
Skis, Wakeboards, Kneeboards
Billgear
Concord
Posted: 05/16/08 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
I don't plan on leaving it open, more wondering it here was special tape to for the that. I've allready opened up where i need to place my through bolts. An yidea what the tape is called for this??
BillGear
gouldc
Edmonton, Alberta Canada
Posted: 05/16/08 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
You could try gorilla tape. Just like the glue it ain't going anywhere.
03' Lariat F350, 6.0L Short Box *SOLD*
04' Jayco Eagle 28FKS *SOLD*
08' FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
07' Keystone Raptor 3712TS PICTURES
Reese 18k Signature Series Hitch
Chickie
Slatington,Pa USA
Posted: 05/16/08 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Why not call any dealer that sells any kind of trailer and ask if they ever heard of it or have it in stock.
