ccjmt4
Arkansas
What is the correct way to weigh a TT. I would assume weigh TV and TT together and then come back and weigh just the TV and subtract the two. It this correct?
donn0128
Pronounced Ore-gun
Right or wrong? Don't know. But what I do is hitch up and drive to the scales. Get the weights of the truck,then trailer. Then drop the trailer and get the truck weighed again. Be sure to get both front and rear axles of the TV independently and together. From this information you can deduce the tongue weight and the actual trailer weight.
Donn
Kenneth
Washington, the state
Yep, you need to weigh the truck & trailer together, or each axle by axle, then weigh just the unhitched truck.
Terryallan
NC
I guess I did it wrong. I dropped the TT on the scale, and weighed it by itself. So I know exactly what it weighed. Didn't have to do math either. Don't care what the truck weighed. It wasn't loaded for camping.
Did mess up when I did the tongue weight. Weighed with the WD bars on. Should have got the weight without the bars.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
crickeydog
Marietta, Ga.
ccjmt4 wrote: weigh TV and TT together and then come back and weigh just the TV and subtract the two.
Yep. And if you really want accuracy, go to a truck stop with a split scale (most truck stop scale's are split) so you can weigh each axle of the truck and TT independently. Be sure to weigh the truck with full fuel, fully loaded, with at least 2 adults in the truck. When you bring the TT back for it's weigh in, make sure the TT is fully loaded with full water and supplies.
Happy camping!!! See ya'll down the road!!!
AIR FORCE RETIRED "EITHER LEAD,FOLLLOW,OR GET OUT OF MY WAY"!
2006 GMC 3500 SLT CC DRW 4X4 D/A LBZ,PREDATOR & FS2500 OIL FILTER
2004 HR PRESIDENTIAL 30 SCD 5'ER.
CHEROKEE & CHEYENNE, MINI DOXIE'S
LOADED LIKE A FREIGHT TRAIN, FLYIN LIKE A JET PLANE!!
fickman
Fort Worth, Texas
Terryallan wrote: Did mess up when I did the tongue weight. Weighed with the WD bars on. Should have got the weight without the bars.
It won't matter, in my experience the scales aren't that precise (within 20-50 pounds or so, but not in the 5-10 pound range). They are used to weight trucks over 60,000 lbs., so they scoff at our rigs. My truck varied 40 pounds when I did the second weigh within minutes of the first.
Best way to get the tongue weight is to buy a scale specifically designed to lower your TT on to.
Here's a thread where I asked several questions about weighing: Link
Everybody was very helpful. . . I tried to be thorough and the forum folk were very eager to answer my questions. Only a few posts long so you might benefit from it.
2005 Chevrolet Silverado 2500HD Crew Cab SB LS 6.0L 4x4 4.10
2005 Fleetwood Pioneer 180CK
DW, DD (born in May, 2007), and me
Dick_B
Palos Heights, IL USA
Even more better is to weigh each SIDE of the TT seperately. It is possible that the total weight on an axle would be under the limit but have one side more heavily loaded than the other.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Terryallan
NC
fickman wrote: Terryallan wrote: Did mess up when I did the tongue weight. Weighed with the WD bars on. Should have got the weight without the bars.
Knew I didn't say it right. What I meant, was. I would have liked to have the tongue weight without the WD bars distrabuting the weight to the front of the TV. I had the rear truck tires off the scale, so that all was on there was the TT. But I had the WDH hooked up, and didn't get an accurate weight for the tongue. I weighed the TT alone, then hooked everything back up, and weighed again. Should not have hooked the bars up.
skipnchar
Topeka Kansas USA
If what you're interested in is the trailer weight just unhitch and weigh the trailer with the tongue on one platform and the axles on the other. No reason to go through any contortions IF that's all you're interested in.
rhondavid
Birmingham, Al
This site will give you step by step instructions and worksheet to use for weighing you rig.
David,Wife,4 kids,SIL,1 foster child,1 grandchild
2003 Ford Excursion Eddie Bauer 7.3 PSD w/3.73 rear end
Jayco Kiwi Too 30T bunkhouse w/triple bunks
Prodigy Controller
Reese Dual Cam HP
Michelin LTX M/S
Topsail Hill Cult Member
