RV.Net Open Roads Forum: Tech Issues: Shore Power Hook Up
 > Shore Power Hook Up
Yeldarb
Omaha, Nebraska
Posted: 05/15/08 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
While I was out last weekend I came across a situation with my electrical hook up. Shortly into our trip I had fired up the microwave when my the power to the microwave stopped and the volemeter on the AC power went to ZERO. I thought, okay I've popped a circuit, NOPE, nothing, HUMMMMMM. Power came back up and I thought maybe the cord was loose so I check all around and everything appeared to be hooked up as it should be. AH, HA, no breakers popped, everything hooked as it should be MUST be one of those bad sites I hear so much about... Yea, that's it. I saught out the host and they commented that the FULL TIME maintenance guy at the park had actually been around the day before and tested all the sites and that mine was reported as working. HUMMMM, now what.
We'll to cut to the chase the maintenance guy came over and we looked at the hook up, all checked out but we discovered the prongs were a bit loose on the male end of my shore power cord and when I actually torqued it a bit and held it tight everything worked well. Ended up putting the 30 to 20 adaptor on and it held the prongs tight and in place and electrical worked fine the rest of the weekend.
NOW, before I go out and buy a new male plug, cut off the old plug and hook up the one should I try it again at my next spot as maybe the 30a outlet was the culprit at the last site? If I do and its still a problem would you actually spring for a new shore power cord or fix it by buying a new plug for the end?
Sorry, king of long winded...
Brad('67) and Valerie('68) Clements
Alyssa('95)
Samson and Toby
2008 Cherokee Grey Wolf 28BH
1999 Chevy Silverado 5.3 3.73 1500 Z71
(Yes it tows my TT quite nicely thank you )
Omaha, Nebraska
Camping Nights in 2008 - 13
Our Camping Adventures
Broccoli1
Los Angeles
Posted: 05/15/08 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
Just a new Plug
06 F250 V10 SB 4x4 Gulp Gulp
WW FSC2800
Rincon 650, Rhino
Power Wheels 750
"Shoot, I'm the world's best backwards driver!"
Kenneth
Washington, the state
Posted: 05/15/08 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
First, take a very good look at things.
If the plug on your cord has bent prongs, yes, install a new plug.
If the receptacle has burned or loose contacts down in the slots, the receptacle is the problem.
nbounder
Arizona mountains
Posted: 05/15/08 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Brad - I bet half of the receptacles (30A) I see are crispy at the mating end. Just for saftey sake, I wiggle it a bit while techno-wife watches the voltmeter, when we hook up. So far, have had no probs, but - I'm sure eventually I'll wiggle my 30A plug and the receptacle will disintegrate. Watch - the park owner will say it's my fault!!
Joe
Mandalay Parr
Phoenix, AZ
Posted: 05/15/08 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
I suspect the park outlet.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
smkettner
Vladivostok, Russia (temp)
Posted: 05/15/08 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
I also suspect the park connector. Do nothing for now.
Broccoli1
Los Angeles
Posted: 05/15/08 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
I suspect Colonel Mustard
Charlie D.
Gonzales, La.
Posted: 05/15/08 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
30 amp are the most commonly used and often are loose or have shown signs of arcing. I usually inspect and if the 30 amp looks suspect or my end does not engage firmly, I plug into the 50 amp with my adapter.
Enjoying Your Freedom?
Thank A Veteran
tvman44
Southwest Louisiana
Posted: 05/15/08 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with Charlie D. That is what I do, I also carry a extra 30 amp plug, you can get them at Wally World. Look at yours and see if the plastic or rubber is bubbly looking by the pins. If it is change it. But get a spare for next time, at the price of fuel it is cheaper to carry one than go hunting one.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Bumpyroad
Virginia
Posted: 05/16/08 05:42am Link  |  Quote  |  Print  |  Notify Moderator
couldn't be him, he was in the library at the time.
bumpy
