RV.Net Open Roads Forum: Hybrid Travel Trailers: draining fresh water tank..SLOW?!
Open Roads Forum  >  Hybrid Travel Trailers
 > draining fresh water tank..SLOW?!
funkoptimus
Rochester, MN
Posted: 05/15/08 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
I filled our tank last night and did the bleach mix to kill any baddie's. But I had to drain some water to do it. But it was really slow. First time doing it and not sure why it was just a dribble. I opened the low point under the fresh tank and I opened the hot and cold low points. I gave up after 30 minutes and used the pump to get it to go faster. Am I missing something?
It is a ROO 23SS
Jamie(the Funkster), Amanda, DD, and Mojo the camp' hound.
Scott_C
NJ
Posted: 05/15/08 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
You don't want to open the hot and cold low points, but vent higher for better flow. Open up your gravity filler cap! Think of it like a can of juice. Use a can opener and punch in one hole and pour, you'll get some out but nothing tremendous, punch that second hole 180 degrees apart and pour again with a nice flow. Your FW tank is just a big can! A low point drain with a high point fill.
2008 Shamrock 21SS
funkoptimus
Rochester, MN
Posted: 05/15/08 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
thanx Scott. Tried that first and it still was pretty slow. How long should it take to drain?
Scott_C
NJ
Posted: 05/15/08 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Honestly, you might then be expecting too much! LOL! They take quite a while to drain through the gravity port - ever notice the ID of the tube? If so, the gate valve, even though full port, further reduces it. In fact, I've been toying with pulling my tank, welding on a large bung, and using 1/2" PEX with a brass ball valve.
jeeperman
florida
Posted: 05/15/08 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
You should only need the cap off the Manuel fill, close the low point drains, and open the tank drain, remember to have the cap off to add water also. air in to empty and air out to add.
LAdams
Northern Illinois
Posted: 05/15/08 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
If your drain is like mine (and most others) I doubt that it is much larger than 3/8" opening and maybe less depending on valve design...
It's going to take a long time to drain 40-50 gallons of water through a 3/8" gravity feed opening...
You might consider making the opening a bit larger and installing a larger valve assembly but those little spigot valves are pretty durn small
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
** NEW ** blog.rv.net
cacutlers
So Cal
Posted: 05/15/08 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
Ours is about a 1.5 in drain and it goes fast.
WillyCoyote
Tecumseh,Ontario
Posted: 05/15/08 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure if this applies to you but mine being new had plastic in the drain hole. Mine had plastic shavings from the holes drilled in it. I stuck a wire up the drain and it came out. I thought maybe a spider made a nest up there but after I did this the plastic dislodged. The water came out much faster.
skipnchar
Topeka Kansas USA
Posted: 05/15/08 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
Small hole drains slow and a large hole drains quickly. Nothing wrong with using the pump to force more water out the LP drains if you're in a hurry though.
Chuck_S
Broadview Hts, OH, USA
Posted: 05/16/08 05:23am Link  |  Quote  |  Print  |  Notify Moderator
The water tank is vented so opening the fill cap probably won't increase flow at all thru the small hose. I think our drain hose twists itself almost shut when I open the valve. I just give the camper a severe tilt toward the tank outlet and pump it dry, refill, pump, etc.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
