I use the pump to move most of it out the low point drain under the sofa. Our dealer's tech showed us that tip and it works great to get most of the water out of the tank.
fortel '01 F150 4WD King Ranch SuperCrew,
5.4L, 3.55 LS, factory tow pkg.
2007 Rockwood Roo 23SS/Equalizer Hitch/Voyager Brake Control
WillyCoyote wrote: Not sure if this applies to you but mine being new had plastic in the drain hole. Mine had plastic shavings from the holes drilled in it. I stuck a wire up the drain and it came out. I thought maybe a spider made a nest up there but after I did this the plastic dislodged. The water came out much faster.
This may be the problem. I had the same thing on my Jayco. Evidently when they punched a hole to hook up the tank, the plastic piece went into the tank and covered the drain hole. Water drained slow.
Dealer managed to get it out and it drains fine now.
It may move by itself once you start traveling but the wire trick sounds good for a try.
GeneKiwi
2006 Silverado 2500HD
2005 Scion XB (the lunchbox)
2007 Jayco Jay Flight 28RLS
I had the same experience (and same fix) with ours the first time I drained it. Drained much faster after I cleared the plastic shavings from the drain.
Brad (40), Cheryl (40), Kaila (17)
'07 F-150 XLT SuperCrew 4x4 with 5.4L V8 and 3.73LS gears
'07 Rockwood Roo 21SS
funkoptimus wrote: Is it ok to run the pump for as long is it will take to drain the tank?? Guessing 5 minutes maybe a bit more.
After bleaching my lines,i want to get the job done so i run outside shower and all low points til she's empty even if it takes 5 minutes or more and then refill and rinse again.
