RV.Net Open Roads Forum: Fifth-Wheels: Power Awning Hits Door
 > Power Awning Hits Door
Vulcaneer
Northern New England
Posted: 05/16/08 05:48am Link  |  Quote  |  Print  |  Notify Moderator
Did the original awning Pilgrim installed interfere with the door??? If not, they lived up to their obligation, and quality control. They manufactured the trailer based on the equipment they supply with it. No way can they anticipate what may be installed post OEM.
Now for the dealer, they should know the clearances needed for the electric awning. And I would bet the installation instructions make note of door clearance.
Dealer error if not installed correctly. They should repair, at no cost to you. And fill the original holes. They'll probably just stuff some of those plastic plugs in them. And tell you if you ever want to go back to the manual awning, all you need to do is pull out the plugs, to install the rail.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
dvdriz
Fenton, MI
Posted: 05/16/08 06:02am Link  |  Quote  |  Print  |  Notify Moderator
The dealer is Kitsmiller in Mason MI and they have been outright rude to me making me feel like an idiot for complaining about it. Their initial attempt at installation they did not install the wind sensor and I found it under neath in a box along with the remote switch that goes inside. Had to go back again to get the rain sensor installed and they still forgot to install the remote switch. I ended up doing that myself.
olchuck
Butler, pa.
Posted: 05/16/08 07:11am Link  |  Quote  |  Print  |  Notify Moderator
my question is if the dealer knew that the awning rails were mounted too low why didn't he put it at the proper height. fiwing the problem and have a satisfied customer!
Charlie and Pearl---George the dog
my home page
2007 Dodge 3500 GUAD CAB, LONG BED, 4x4, HO Cummins
2003 Arctic Fox 29-5t
Roy T
Dodge City, Kansas
Posted: 05/16/08 11:42am Link  |  Quote  |  Print  |  Notify Moderator
The dealer is supposed to be the manufacture's representative. He should fix all problems and work it out with the manufacture. He needs customer satisfaction or he's out of business.
dvdriz
Fenton, MI
Posted: 06/04/08 06:02am Link  |  Quote  |  Print  |  Notify Moderator
OK I found the installation instructions for the power awning and it should be mounted a minimum of 12 3/4" above the door frame and add another 2" if the door falls in the center, which it does. I measured it and the awning was mounted 9 1/2" above the door by my dealer. That makes it almost 5" too low! I wrote the CEO/Owner of the dealer a letter so we will see what happens from here. Clearly a gross error on the dealer's part. More to follow...
DelawareCamper
Newark, Delaware
Posted: 06/04/08 06:13am Link  |  Quote  |  Print  |  Notify Moderator
Write to the "RV Action Line" that is in every month of trailer life
check out www.trailerlife.com
gpshemi
Lapeer, Michigan
Posted: 06/04/08 06:16am Link  |  Quote  |  Print  |  Notify Moderator
Keep us up to date. Thanks for posting the dealers name too. I'm in Michigan too and I'll remember that sort of thing.
GPSHEMI
06' 3500 Dodge Ram Megacab 4x4 w/5.9L Bully Dog Triple Dog
16K Pullrite SuperGlide w/super rails
05' Laredo 29RL (32'10")
donhov
near Jackson Michigan
Posted: 06/04/08 06:41am Link  |  Quote  |  Print  |  Notify Moderator
If you find Ron (the owner) he has always been a good person to work with. I would politely show him the mounting instructions and explain the problem and the lack of concern from his employees. If he is the same person and his success over the last few years hasen't gone to his head, I would think he would make sure it is done right.
JMHO though
2003 Cedar Creek 30RLBS
2007 Dodge 5.9 Cummins Turbo Diesel 325hp/610Tq
4x4 3.73 axles short bed
Inferno Red W/Gold pinstripping
dvdriz
Fenton, MI
Posted: 06/25/08 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Apparently his success has gone to his head. I wrote a detailed two page letter to him over one month ago. Unfortunately he, or his staff, never even took the time to respond. Also after I initially posted this I was also told by another RV dealer in Georgia the hitch that was installed by Kitsmiller is too small for my fiver as it is very overloaded and I confrirmed this with Reese directly. I think this is all due to the great deal I negotiated up front and they just don't care about customer service in my case. We all have a choice of RV dealers in Michigan and I personally will never give this place my business ever again.
2-MTnesters
carrollton, Ky
Posted: 06/25/08 07:46am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like they aren't concerned about customer safety either!!!
The Webers
Me- Tim
DW- Dea
Pooch- JoJo boxer/lab mix
2008 Coachmen Chaparral 270RKS "The TajMahaul"
1999 GMC Siera 2500 x-cab 4x4,6.0,3:73 gears, Reese 16K slider
