Fred & Gerry
Laurel, Delaware
I have been thinking about installing a front mounted hitch on my 2002 2 wheel drive Chevy Suburban. We wonder if it would be easier to maneuver the trailer into the tight parking spot we have at home. Does anyone have any experience with one and would this work better than trying to back it in with my wife's "help"!
Thanks
Fred Johnson
Mandalay Parr
Phoenix, AZ
Go for it. Yes, yes, yes.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
mistressofdistress
Memphis, TN
Very different than backing trailer in, turns much quicker. After you get used to it you will like it.
agesilaus
North Florida
Everyone I have heard that did this was happy with the result with one exception. He overloaded his TV power steering unit and blew out some hoses. Otherwise it seems to allow precise maneuvering of the TT.
There are power dollies available to move TT but they are out of my price range at $900 or so. The front hitch receiver seems to run around $150-200
BK
04 Trail Manor 2619
08 Ford F150 5.4L TV
tesctom
NJ
You can't beat a front hitch for putting a trailer in a tight spot, also great for launching a boat. I'd call it just plain handy.
Dick_B
Palos Heights, IL USA
For more responses you could search this forum for `front hitch' where there are more then 300 responses.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
skipnchar
Topeka Kansas USA
My advice would be to learn to BACK the trailer in. You may ALSO find some tight spots in campgrounds or maneuvering around gas stations and keeping everyone else waiting while you unhitch and turn around would be a pain. there is really no reason you can't learn to back into any spot you can pull forward into with just a little practice.
IPegasus
Wisconsin
I use a front hitch mounted on my tractor (not lawn tractor, is a big tractor). I use it to manuver my trailer inside my storage building. If you have room to manuver your truck around, backing is easier because you can use your mirrors to see where you are going. With the front hitch you are blind on both sides.
2003 Chevrolet 2500HD DA LT 4x4
Class 5 Air Safe Hitch, Reese DC HP, Ultrafab 3500
1999 Wilderness GL 27F
Scott_C
NJ
A front hitch will indeed make it easy, but simply practicing backing will do you just as well. Find an empty parking lot and work to put your trailer between the painted lines of the spaces. Throw out some cones/buckets/whatever as obstacles and you'll find yourself getting the hang og it pretty quick. One big newbie mistake is trying to cut too tightly - close to a jack-knife position - because you'll never get that to work (barring a 5er or goose, of course). You need gentle arcs.
2008 Shamrock 21SS
swebber
Brunswick , MD
IPegasus wrote: If you have room to manuver your truck around, backing is easier because you can use your mirrors to see where you are going. With the front hitch you are blind on both sides.
My thoughts exactly !
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
