RV.Net Open Roads Forum: Fifth-Wheels: King Pin Lubrication?
 > King Pin Lubrication?
Roy T
Dodge City, Kansas
Posted: 05/16/08 11:34am Link  |  Quote  |  Print  |  Notify Moderator
The lube plate is a must. Also you will need to lubricate the moving parts of the hitch to keep things working properly.
keith and sharon
Van Nuys, CA.
Posted: 05/16/08 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
Lube plate is a must, we went camping at the beach with a friend, who will only do what "the truckers do" by applying a thick layer of grease on the hitch plate, the weekend we stayed at the beach the wind was blowing from the water, his hitch plate looked like sand paper.
2008 Tiffin Allegro 32BA
2008 F-150 King Ranch
2008 Escape Hybrid (toad)
FMCA #F402618
DCHaviland
Pearland, Texas
Posted: 05/20/08 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
mellis68 wrote:
Ok, no laughing out there but I bought my first fiver last year so this is my first time "de-winterizing" and hitting the road. Is there anything I need to do to lube the king pin? I see other postings about a "hitch plate" which I don't have....at least I don't think. It would seem that I could lube the pin so it rides smoother in the hitch.
Hi... I use the nylon slip disk and was told by two dealers that I didn't need any sort of lube other than maybe a shot of WD-40 around where the latch binds the king-pin. As I remove my 5th wheel hitch with some regularity (yes, I actually need my truck for something other than hauling the 5th wheel) the last thing I wanted to do was get all "greased up" taking the hitch off.
I know two guys that did use grease and now that they know about the nylon disks, they wish they could go back. One is trying!
David
Arnie - Ford F-250 Diesel 4WD
Maria - 31' FR WildCat
rsherrie
Littleton,CO
Posted: 05/20/08 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
DCHaviland wrote:
Hi... I use the nylon slip disk and was told by two dealers that I didn't need any sort of lube other than maybe a shot of WD-40 around where the latch binds the king-pin. As I remove my 5th wheel hitch with some regularity (yes, I actually need my truck for something other than hauling the 5th wheel) the last thing I wanted to do was get all "greased up" taking the hitch off. David
I would say that this advice is not in your best interests. WD40 is not enough lubricant for the jaws and pin. There is a lot of weight excerting pressure on these parts and a little grease is a much better lubricant. You don't need much so it won't make a mesh. I have seen worn out jaws and they aren't cheap to replace (retired mechanic)
smkettner
Posted: 05/20/08 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
For the actual pin I use Slip Plate graphite spray.
Paul Clancy
BC Canada
Posted: 05/20/08 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
No grease or wd40=seized hitch. Happened to me and I was given the same bad dealer advice. White lithium or equivalent INSIDE the mechanism is a must or carry a big sledge for when it stops working.
