RV.Net Open Roads Forum: Help, need to find a place to have baseplate attached...
Search only in Tow Vehicles
 > Help, need to find a place to have baseplate attached...
planetcomet
California
Posted: 05/15/08 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
As we are new to rv'ng and will be fulltiming, we are trying to find way to have a tow bar or baseplate put onto the front of our jeep wrangler to tow.We already have the roadmaster sterling, hitch, the lighting system, but can't find a decent rate to connect the base plate to the jeep and have the electrical done. Some places say we don't need to bring in Rv with the jeep to get work done, other places say we need both, to have it done properly ( wiring the jeep and attaching the plate to front of jeep.
Camping World too expensive, and we are heading from Palm Springs to Oregon, with a stop in Redding ( I know a place there, but we have to be in by 8:30 a.m. to have 2 guys do the work, thus cutting time. There is a place out here in Bermuda Dunes, but seems pricey. Would hate to have to drive seperately till we get to redding as we are pressed for time, money and I start my travel nurse job in 2 weeks.
Any suggestions would be really helpful, esp. if you know places near Palm Springs that would do this at a reasonable price ( not a dealer). Our Rv is a 35 ft. Class A, SeaBreeze, 2005. We really need some good advice on this one. PLEASE, WE NEED HELP FAST!!! Thanks, Suzanne and Ric
Kenneth
Washington, the state
Posted: 05/15/08 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
You might get more responses if you ask the moderator to move your question to either the "dinghy towing" or "Class A Motorhome" forums. This one is actually Towing Vehicles. Your Jeep is a towed vehicle (toad).
rjstractor
Auburn, WA
Posted: 05/15/08 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
If you think Camping World is too expensive, you probably won't find anyone else much cheaper. Hitch and towing work is really not something you want to go cheap on, if you think about it. You have a large investment in both your MH and toad. Do you want to jeopardize that to save a couple of hundred bucks? If you want it done right and you can't do it yourself, you have to pay up.
1998 Gulfstream Ultra B/H Ford E450 V10
2005 Chevy 2500HD 6.0 w/ Maxidump insert
6x12 Interstate enclosed trailer
7x16 Bulldog flatbed hauling a 2006 Kioti CK20 TLB
2003 Ford Explorer Eddie Bauer
1998 Saturn SL2 toad
goldendagger
ocala,fl
Posted: 05/16/08 01:28am Link  |  Quote  |  Print  |  Notify Moderator
you have to tie into the frame where the bolts that go through the tow hooks are used...you will need longer bolts, make sure you use grade 8 min. if your base plate does not fit there than you do not have a wrangler base.
who left the light on? is it me or are we leaning downhill. where did the dog run off to
Joy
Henderson KY 42420
Posted: 05/16/08 06:32am Link  |  Quote  |  Print  |  Notify Moderator
The dealer who installed ours charged $600 - about the going rate - it takes most of a day to do, I was told. Any RV dealer with a shop can do the work - some car dealers (ours was where we bought the toad) are experienced at this, too.
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Katie-Mini Aussie
Sam-Calico Fat Cat
Maggie-Chihuahua
2003 38'Phaeton DP
2006 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
fireman50
Tennessee
Posted: 05/16/08 07:26am Link  |  Quote  |  Print  |  Notify Moderator
I bought the Blue Ox base plate for my Wrangler and did it myself. The instructions are pretty clear. Took about two hours. The light wiring took roughly another hour.
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/16/08 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Unless your baseplate install requires welding, it shouldn't require a professional to install if it comes with the hardware and instructions. If you can operate a drill, a wrench and a measuring tape, you can probly do it yourself for free. Installing the tow bar on my Bronco just required drilling 4 holes and bolting on the mounts to the bumper (Bronco was made back when bumpers were real). I am a welder, but didn't need to do any welding to install it and was very easy and straightforward.
The light and brake wiring, well if you're not familiar with auto electric, you might want to have someone do that for you.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
2manytoyz
Central FL
Posted: 05/16/08 11:26am Link  |  Quote  |  Print  |  Notify Moderator
You didn't say what year your Jeep is.
I installed the base plate, and wired up my (previous) 2004 Jeep Wrangler myself.
Having installed one now, installing another complete setup, would only take "me" about an hour. Most of it is all bolt on. Did have to drill one hole, but a piece of cake. During my install, I spent more time trying to decide the best place to route the wires, and place a connector. The RoadMaster kit came with everything I needed, except for a Torx bit needed to remove bumper bolts on the Jeep. I bought a kit from Sears, the rest of the job needed only common hand tools and a drill (one hole through frame).
I posted details about my install, along with pics, at this link.
I can see a shop charging $600, only because there are so few of us hands-on types left. $200 would probably be close to the actual worth, IMHO. A lazy tech shouldn't take more than 2 hours.
No, they don't need your MH to put the base plates & wire up your Jeep. I modified my Jeep BEFORE buying my previous 36' Class A. Plug and play after I bought the MH.
The one extra thing I had to buy was a 6" drawbar drop. The towbar should be fairly close to level. Mine was too high on the MH end. Went to the Camping World store at Lazydays (whom I purchased the MH), and had to ask at the parts counter. Was not a product out on display. This item slips into the MH hitch receiver, and has another receiver box below. There are various levels of drop available: Link. Link2
Robert
Cocoa, FL
2007 Rockwood TT 2502
Equalizer Hitch
Prodigy Brake Controller
2005 Nissan Xterra
2006 Jeep Wrangler Unlimited
Yamaha EF2400iS
