RV.Net Open Roads Forum: Class B - Camping Van Conversions: Roadtrek Inverter
Rodger
Tucson, AZ.
Posted: 05/17/08 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
A lot of laptops will run fine on a MSW here are some items that do not run well on a MSW.
Laser printers, photocopiers, magneto-optical hard drives
Certain laptop computers (you should check with your manufacturer)
Some fluorescent lights with electronic ballasts
Power tools employing "solid state" power or variable speed control
Some battery chargers for cordless tools
Some new furnaces and pellet stoves with microprocessor control
Digital clocks with radios
Sewing machines with speed/microprocessor control
X-10 home automation system
Medical equipment such as oxygen concentrators
Visit My Roadtrek
Hey, check out the new RV.Net Blogs!
Rodger
Tucson, AZ.
Posted: 05/18/08 05:47am Link  |  Quote  |  Print  |  Notify Moderator
I suggest buying a
Kill-a-Watt Meter
Power factor displays:
Volts
Amps
Watts
Hz
VA
KWH
I use the volts & Hz to adjust the governor on the Onan 2800. If your generator surges it's quite likely running too slow, and the voltage, and frequency will be affected. It seems my needs a little adjustment a couple times a year.
You can use the Hz, to check the frequency of your microwave while running on the MSW inverter. Should be 60Hz, but you will probably see something in the 50Hz or even 40Hz range.
loggenrock
New Hampshire
Posted: 05/18/08 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Rodger! Where is the adjustment for the gov'nor on the 2800??? I only find the altitude adjustment... Thanks! ST
2003 Roadtrek 190P Chevy 3500, and a pair of Limmers...
